Help! Rear shelf w/Bose removal
If searched and can't find a good write up. Bentley manual has no info for the Bose option.
I see tabs (4) in the carpet but can't get the rear ones off (feels like they'll break)
Id say its a very similar if not exactly the same as the 997 Bose sub removal procedure:
https://www.6speedonline.com/forums/997/247791-997-1-coupe-bose-sub-removal.html
1. Pull out the two "Bose" plastic port enclosures=left
2. Use a torx driver to remove the torx screw on each port=left
3. Slide the entire back panel forward=left
4. Unclip the wires to the sub woofer=left
=left
Be careful not to break the tabs on the plastic port enclosures
Is there a trick to getting the ports out without breaking them?
=left
Mine come off with no problem. I've done it many times, as I have to remove the sub-woofer to get to the adjustment for the rear dampers. Just pull forward gently and they should release.
=left
=left
