996 Forum 1999-2005
996 shock replacement
Old 02-21-2019, 12:00 PM
jdoc1949
jdoc1949's Avatar
Default 996 shock replacement
I have a 2003 Targa with 74,000 miles, looking at replacing old shocks are the Koni active shocks okay, Im just looking for good street replacement as I have some long trips this summer in the works.
John
Old 02-21-2019, 12:12 PM
parris
parris's Avatar
I would recommend Bilstein B4 (Exatly like OEM) or B6 (a little bit sportier, but with the same riding height). Curiously, for our cars, the B6 are cheaper than the B4...
Old 02-21-2019, 01:56 PM
DGI
DGI's Avatar
Bilstein B6: http://www.carnewal.com/products/996...cks-for-996-C2
ROW M030: http://www.carnewal.com/products/996...ension-Package
Old 02-21-2019, 07:52 PM
Augustus Barone
8th Gear
Augustus Barone's Avatar
another option, includes bump stops and dust covers
https://www.paragon-products.com/Sus...-p/ksa-996.htm
cpsneineleven (11-28-2023)
Old 02-21-2019, 10:33 PM
Skyman911
Skyman911's Avatar
I'm curious about this as well. I'm also a Targa owner. What about upgrading the springs to something like an H&R spring along with the Bilsteins? I'm not going to really track it much and want to keep a stock type of ride while improving the stance and handling.
Old 02-21-2019, 10:53 PM
Mike Mullins
Mike Mullins's Avatar
Default 03 Targa with H&R Sports and B8's Bilsteins
Shot on iPhone _edited w Lightroom6 /MacOS
Bilstein B8's
H&R Sport Springs
23mm Rear and 15mm Front Spacers
Drop - 1.25" front and rear
26mm H&R Adj Rear Sway Bar (middle)
Stock Size Conti's
Setup works and I think even better, it fits, No rubbing
Be careful on driveways
shot on iPhone, edited in Lightroom 6 / MacOS
Old 02-21-2019, 10:58 PM
Mike Mullins
Jason is a great supporter , I've bought some great stuff from Paragon over the years
Old 02-22-2019, 11:03 AM
Neto
Neto's Avatar
I have the koni yellows with H&R springs on my car, I use the car daily and the ride quality is good.
Old 02-22-2019, 11:18 AM
Nickshu
Nickshu's Avatar
ROW M030 OEM Porsche. Available from Suncoast or Carewal.
I would recommend replacing the strut top mounts and bearings, especially the fronts. These are not included with the M030 kit. If you really want to refresh everything then replace all suspension arms and swaybar drop links at the same time.
I will admit I am guilty of "where do you stop?" syndrome. I would do wheel bearings and at least regrease the half shafts with new boots too while I was at it. LOL. I have a sickness.
Old 02-22-2019, 11:27 AM
parris
parris's Avatar
^^ You read my mind. I have just made the RoW C4S suspension on my car, together with front strut mounts and bearings, and the result could not make me happier.
Old 02-22-2019, 11:33 AM
jdoc1949
jdoc1949's Avatar
Thanks for all the advice, simply put the car has been in the south all its life before coming to Kansas City, all arms, boots etc are in great condition. Shocks seem to be a little "mushei" I have the chance to buy a new set of Red Koni actives for $700 or could go the Bilstein B4 @ $1218. I am only street driving and some long road trips, Watkins Glen this year.
So just looking at these 2 options ???
Old 02-22-2019, 11:47 AM
parris
parris's Avatar
I know the price is quite higher, but I would go with Bilstein
Old 02-22-2019, 12:03 PM
Sula
Sula's Avatar
Originally Posted by jdoc1949
I have the chance to buy a new set of Red Koni actives for $700 ...
Where are you finding that price?
Old 02-22-2019, 12:18 PM
hatchetf15
hatchetf15's Avatar
OP: If you haven’t looked at the M030, you should. Value and the way the car should’ve been spec’d as ‘std’. Shocks, struts, springs and sways for a very reasonable cost. You can even find the X74 front tops...not cheap, but less $ than the Taretts or Elephants...for full factory flavor. The only pick I have with the M030 is I’d like about 13mm more drop.
Full M030 and 15mm spacers all corners. PS4S shoes on 19’s.
Old 02-22-2019, 12:53 PM
SoundnSpeed
SoundnSpeed's Avatar
^^ Same on my daily driver 1999 C4 - replaced stock with RoW M030 from Carnewal, including additional items as Nickshu noted at Gert's recommendation, at about 153,000mi...Ride is great... missing spacers that improve look and agree with the desired drop.
Last edited by SoundnSpeed; 02-22-2019 at 12:55 PM. Reason: corrected reference to Nickshu
jimham968 (07-18-2019)
Quick Reply: 996 shock replacement
