Battery Tender Suggestions
I've been driving the P-car a lot less this winter since my DOT has decided to coat the roads with 6 inches of salt whenever the temp gets below 40 degrees so I'm looking at options for a battery tender to keep things charged and ready to go. The only time I've used won before was for my motorcycle and I've always used the Battery Tender brand. I know there are others out there and was wondering what the Rennlist community would recommend for my car? Thanks...
This ^^^^^
I use the Battery Tender Jr. in fact, I have 3 of them, one for the 996, one for my motorcycle, and one for my boat. All work perfectly in all applications.
i keep a harness wired to the 996 battery all year around and just plug into it as needed.
I use the Battery Tender as well (the one for two cars - https://www.zoro.com/battery-tender-...BoC5bAQAvD_BwE ). I've got mine set up the same as above (with quick connect plug). I'be been using it for 4 years - no problems either with the unit or with starting cars after long winters...
Ctek has performed flawlessly for 3+ years, 2 on 2 cars
semi-permanent install
If you're in the habit of not driving your car for 3+ days at at time, just pop the frunk (assuming it's garaged) and plug it in
The one time I got caught with a low / dead battery was enough, no reason for it
I used an extension and ran it to just under the cap that covers the cowl:
Received 1,085 Likes
Different. Schumacher Auto Battery Maintainer. I got this little guy at Autozone, but here it is at Wally World. Works great through the cigarette lighter. My battery is AGM.
https://www.walmart.com/ip/Schumache...SABEgIqpfD_BwE
C-tek MX5.0
Also plenty of accessories for it - you can also charge via cigarette lighter and there is a cut out in the door seal for the wiring
