996 Forum 1999-2005
First Porsche advice
Old 01-30-2019, 11:43 AM
911Syncro
911Syncro's Avatar
1. Be very careful to distinguish facts vs. opinions. (Too often "facts" written on the forum are just hearsay).
2. Read as many published articles as possible here: https://rennlist.com/forums/996-foru...-articles.html
Old 01-30-2019, 11:46 AM
e90steve
e90steve's Avatar
Originally Posted by cds72911
They all have a high possibility, even of the probability is low. By that kind of logic, people would be wise to avoid all 996 and 997 before the 997.2, because there is a known risk (“possibility”). Doesn’t make sense to me, but that may just be me. Leaves more 2000’s for the rest of us, I guess.
I love all 996's so not picking on 0/01's. But personally if I'm "risking" the possibility of potentially having what's universally considered the weakest of the bearings (Some 00, All 01-05), then I at least want the added benefit of having the larger engine is all I'm saying. The 99 on the other hand is a known variable and somewhat different of a 996 being the first model year. It has some additional charm to it that is being recognized by pubs and experts out there.
Old 01-30-2019, 11:49 AM
TexSquirrel
TexSquirrel's Avatar
Received 2,389 Likes on 1,266 Posts
I've found that many "published" articles about the 996, even positive ones, often are not always accurate.
Old 01-30-2019, 11:56 AM
Nifty911
Nifty911's Avatar
Simple answer from someone who has had three.
Find the nicest one you can afford and have a pre-purchase inspection done, then decide from there.
Old 01-30-2019, 12:20 PM
6L6
6L6's Avatar
My 2002 cab was perfectly maintained from new. However, at 72K miles a tensioner failed and the engine grenaded.
Since it is cheaper to just buy another 996 than to buy and install a rebuilt engine, I sold it as a roller for $5K.
My advice: replace the tensioners immediately.
Personally, I'd only buy a 996 that has the following:
* 6 speed manual
* Cabriolet
* 2 wheel drive
I don't think you can beat these cars for sheer fun factor. Somewhere down the road I'll be getting another, but it will be a 997 that doesn't have the inherent engine design issues.
Bill
MattBurns
MattBurns's Avatar
I rolled the dice on my 2000 since the build date is 7/99. Haven't had it on a lift yet to look at the IMS flange, but I think I have a very good chance it has a double row bearing. At any event, with 120K on the clock I fully expect some sort of mechanical issue with the motor to creep up at some point. When that happens, it will come out of the car and go through a bulletproofing (IMS solution, RMS, AOS, timing chain guides and tensioners).
Old 01-30-2019, 12:26 PM
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Originally Posted by TexSquirrel
@Scott at Team Harco, you need to update your signature.
There's no mention of your 996.
Good point - leaves my previous comment ungrounded.
There is also no mention of three Audis and a bunch of other junk we own....
Old 01-30-2019, 01:39 PM
Mib44
Mib44's Avatar
wow, thanks guys for all comments! I didn't expect so much feedback. Keep it coming!
I'd get you some more info to clarify my needs:
I currently own a 96' bmw m3, full cage etc, tryin to sell it. I was only doing Time Trials in it and I have a trailer to take it to the track.
I decided thats too much hassle and I need a fun car to drive TO the track and ON the track, and sometimes drive it around for some errands.
I've seen some videos and I'm prone to RWD, of course manual. Please do not offer me a miata) Firstly, I'm pretty tall and don't fit in it, I know they're good at the track. Secondly, I just don't like them) Thirdly, like I said, I had already dedicated car for the track and mazda is no fun to drive around the city))) that's why I'm looking 2 in 1. Also, I do have second car as a daily driver, so no problem if Porsche is in the shop.
Thanks again, and keep the comments coming)
Old 01-30-2019, 03:28 PM
TexSquirrel
I came from the BMW world too.
I had a 2009 BMW 135i with a N54 that put out 500 rwhp that was my daily driver.
It was fun in a straight line, but not the best track cars.
My 996 is slower than my BMW in a straight line, but is SO much more fun.
I enjoyed the 996 so much that after I realized I hadn't driven the BMW in two months I decided to sell it and throw the money into the 996.
(Suspension and track preps)
Old 01-30-2019, 04:16 PM
e90steve
e90steve's Avatar
I had a cobb tuned e90 335i N54 w/ FBO Stage 1+. That thing was a boosted rocket ship and handled incredible after I swapped out the M suspension. Had a 996 C4S at the same time and ended up selling the C4S because it wasn't nearly as capable.
That said my current 996 AE is way more of a special "experience" to drive even though it has way less HP.
Old 01-30-2019, 04:27 PM
bull3t
bull3t's Avatar
Originally Posted by michaelo
Do not get a manual,
Do not get Litronic headlights, when they fail it will be expensive to fix
Do not get all leather interior - unless it is perfect
Flame on.
I couldn't imagine driving an automatic 996. I'd rather own a corolla.
I had one of my litronic ballasts go out and it was like $30 to replace
I highly recommend black full leather, makes the car feel really high end and after 20 years it still smells new.
Old 01-30-2019, 04:35 PM
bpoteat
bpoteat's Avatar
Do not get a manual, When the pinion gears go bad it will not be easy or cheap to fix or replace.
Do not get the all wheel drive as it has a front differential and when it needs to be fix or repaired it won't be easy or cheap.
Do not get a year with the single row IMS bearing
Do not get headlight washers
and finally...take an NA lightweight Miata to the track, not a 996 Porsche.
Flame on.
I've disagreed with parts of suggestions in a post before but I don't think I've ever seen a post that I 100% disagree with on every single point.
Old 01-30-2019, 08:18 PM
Woodman71
Woodman71's Avatar
I owned a stick Corolla and a Tip 996 at the same time, and drove the Corolla 5 times more.
I kid, I kid. But I tend to agree with you.
Old 01-30-2019, 09:39 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,580 Likes on 987 Posts
Originally Posted by Mib44
Hi,
I plan to purchase a 996 for around $15-20k. Never had a Porsche before and I have lots of questions. Will really appreciate if someone would go over in details.
I want to use it as a fun car, take it to the track a few times a year.
- would you recommend 3.2L (1999-2001) or 3.6L (2002+)?
- how expensive is maintenance, what should I expect?
- are the engines still reliable after 100K+ miles or better to look with less miles?
Thanks!
Maintenance is similar to any other German car, but Porsche parts can be more expensive. Case in point, a 100k mike car that may need an engine rebuild might cost $10-$20k. I would buy the nicest car you can afford with the lowest mileage (except for cream puffs that are very low mileage). Those will be much higher than your budget anyway.
Old 01-31-2019, 03:35 AM
Noz1974
Noz1974's Avatar
Originally Posted by Scott at Team Harco
Good thing I didn't see this before my purchase.
Oh - wait. It wouldn't have mattered.....and still doesn't.
Don't get manual??
Quick Reply: First Porsche advice
