996 Forum 1999-2005
Trickle charger setup, this look right?
Old 01-27-2019, 01:32 PM
searching4996
searching4996's Avatar
Default Trickle charger setup, this look right?
Hey Everyone,
This was my first time setting up the battery charger on this car. I read the owners manual and, to be honest, ive never seen a setup like this on any other car. It said to hook it up to a fuse you pull out of the fuse box, then connect the positive cable to the handle where the door goes. I followed the instructions to the letter ( see attached) just want some validation that I did it right. Is this the right setup?
Old 01-27-2019, 01:36 PM
Sula
Sula's Avatar
Your setup should work, provided that the fusebox lead is at 12v. Note that you've (correctly) connected the black (= ground) lead to the body of the car. It would be a serious mistake to connect the positive lead there, as your text implies.
Definitely simpler: Attach charger to the car's electrical system via a plug that connects to the cigarette lighter.
Old 01-27-2019, 01:38 PM
JTT
JTT's Avatar
This is typically how you jump the hood/rear hatch releases (to open frunk and engine lid if battery is dead). You don't need to go this route, just to charge the battery. Either simply open the frunk and remove the battery cover (plastic cover with two thumb fasteners up toward the windscreen) and place clamps directly on battery posts....or you can charge directly to the cigarette lighter, but you need to gear up an adaptor to plug into the lighter port.
Old 01-27-2019, 01:52 PM
searching4996
Ok that sounds like a great way to charge the battery, I never knew that was possible. So theres an attachment that you can charge the battery via the cigarette lighter? where would I find one of these? By the way thanks for the reply
Old 01-27-2019, 01:53 PM
searching4996
Thank you, where is the rear hatch /frunk release?
Old 01-27-2019, 02:01 PM
Botsy67
Botsy67's Avatar
Since I have owned my 996 cab (13 yrs+), I have been using the OEM Porsche trickle charger through the cigarette lighter port for the winter months hibernation and never had any issue. You can use Google to locate one online, many places have them. Cheers,
Sula
Sula's Avatar
Here's an example: https://powerwerx.com/cigarette-ligh...e-adapter-18in
Or, you could find some outdated item (old radar detector ?) designed to be powered via the cigarette lighter and lop off its cord.
Old 01-27-2019, 02:04 PM
HenryPcar
HenryPcar's Avatar
Seems like an appropriate way to trickle charge a German car. Goes with the territory of over-engineering instead of a more direct, simple, fool-proof way of accessing the battery under the frunk.
Old 01-27-2019, 02:15 PM
JTT
JTT's Avatar
Thats what I did. Just took an old device with plug, chopped it off and connected the wires.
Old 01-27-2019, 03:08 PM
wildbilly32
wildbilly32's Avatar
Direct to battery or cigarette lighter. That way you can shut your door! The instructions you followed are for hooking another battery to assist in opening the frunk on a MK2 with a dead battery. And by trickle charger assume you mean battery maintainer.
Old 01-27-2019, 03:17 PM
searching4996
Yes that's what I meant, and thank you!
Old 01-27-2019, 03:18 PM
searching4996
I love it, thank you!
Old 01-27-2019, 03:21 PM
Sula
Sula's Avatar
Not sure if they qualify as over-engineered, but there are easily accessible high-current jump-start connections in the engine compartment.
Old 01-27-2019, 03:35 PM
go.illini
go.illini's Avatar
I use an OBD connector with my Batter Tender.
Hopefully I don't get flamed for suggesting this like I did on the 991 forum...
Old 01-27-2019, 03:47 PM
cds72911
cds72911's Avatar
This approach seems unnecessarily complicated.
Why not just connect directly to the battery? Or add a lead from the battery to a convenient location - Battery Tender makes some decent ones with SAE connectors.
Quick Reply: Trickle charger setup, this look right?
