996 Forum 1999-2005
How bad did I screw myself
Old 01-16-2019, 06:36 PM
996Silver
3rd Gear
996Silver's Avatar
Default How bad did I screw myself
Got a new to me C2 Cab.
While changing the spark plugs, I dropped one while pulling it out and it's in the cylinder. The tube came out with the coil pack and the spark plug is where the tube would be. I can feel it where it fell, but cant seem to get it out.
Old 01-16-2019, 06:39 PM
808Bill
808Bill's Avatar
Is it still vertical? Try a piece of rubber hose or a magnet from the auto parts store.
Old 01-16-2019, 06:50 PM
996Silver
3rd Gear
996Silver's Avatar
There is what appears as a small crevice just inside the hole for the spark plug. It seems to be wedged down there and turned sideways.
Old 01-16-2019, 06:57 PM
Turbodan
Turbodan's Avatar
as mentioned above use a magnet or another type of grabber sold at automotive parts stores that can grab it like this:
Amazon Amazon
or you could turn the car upside down and shake it out
Old 01-16-2019, 09:45 PM
Flyfishnick
Flyfishnick's Avatar
LMAO, not at you please understand, but that is why I choose not to do certain engine fixes myself. I always (ok, most always) make the job more difficult than it needs to be and then pay someone to fix my 'oopses'.
Again, sorry for your luck. I can see me doing the same thing. You'll get it out.
Old 01-16-2019, 09:48 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
https://www.lowes.com/pd/Kobalt-Flex...yABEgJDoPD_BwE
Lowes is open until 10PM in many areas
Old 01-17-2019, 05:59 PM
jims911
jims911's Avatar
How about a small diameter attachment on your shop vac?
Old 01-17-2019, 06:49 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,576 Likes on 983 Posts
You didn’t screw yourself, you plugged yourself. Let’s be clear. You will be able to get it out with enough creative thinking and attempts.
Old 01-17-2019, 09:10 PM
Coopduc
Coopduc's Avatar
If I understand correctly, it’s not in the cylinder, but rather under the cam cover in the area of the valves and cams??
Old 01-17-2019, 10:00 PM
HoustonCgrBkr
HoustonCgrBkr's Avatar
Oh man, I feel for you. It is something that would happen to me. I had something break off when I was changing plugs on my motorcycle. I ended up getting creative. I could lift it but not pull it out. I had to fashion a suction hose small enough on my shop vac. It did the trick, but only after about 4 other solutions failed.
Old 01-17-2019, 10:21 PM
Flyfishnick
Well, did ya get it out?
Another idea if shop vac or grabber doesn't hold--hot glue gun, glue that sucker to something flexible you can pull it out with?
Old 01-17-2019, 11:10 PM
996Silver
3rd Gear
996Silver's Avatar
It ended up coming out with the help of my 8 year old son and small hands being able to grab and turn it and pull it out
Old 01-17-2019, 11:48 PM
turbogrill
turbogrill's Avatar
I feel for you! Once dropped a small screwdriver inside a nissan engine block. Did I feel stupid...
glad it worked out!
Old 01-18-2019, 12:34 AM
TexSquirrel
TexSquirrel's Avatar
Received 2,389 Likes on 1,266 Posts
Awesome!
Old 01-18-2019, 01:11 AM
dkraige
dkraige's Avatar
Great! Good for young people to get hands-on problem-solving experience. Too many people grow up having never fixed or worked on anything!
Quick Reply: How bad did I screw myself
