Got mine in today. Has anyone hooked up the option with led lights? Where did you wire that in?
I don't own one, but if I were doing it I would wire it to one of the window switches.
There is a wire for the back-lighting for the window switches, and they're really close by.
Correct this is how I wired mine a couple of the posts on the switch are for lighting.
I didnt think about that. I was looking at the dash.
do you recall what posts are for the illumination?
I can get the voltmeter out, but if you happen to know off hand ...
The ones towards the front of the car if I remember correctly.
Looks sharp! How do you like the feel of the round ****?
I actually like how the factory shifter/**** feel in my hand.
Absolutely love the feel. I originally ordered the alloy round shift **** and switched to this one. I also installed the Function First shift kit that massively improves the shift action (does not shorten the throws). And installed the modified shift detent in the transaxle to prevent the kicking-out of 2nd gear. I am thoroughly pleased with the results.
