Strut Replacement - Seeking Advice
How do you like the Koni Yellows? I am considering them myself. Currently on Stock Struts and Eibach Springs with their Sways soon to be installed.
IMO, if I was going to go through all the trouble of replacing the struts id just pony up to extra coin for a good set of coil overs. They arent an incredibly expensive upgrade.
When I did mine, I used these on the coils while they were still compressed on the car. It made it easier when trying to clear the fender lip for removal.
The piece of foam pipe insulation in the pic was placed on the edge of the wheel well along with a piece of hose over the threads of the strut to help protect the paint when removing.
Ok, just my opinion which I'm quite positive many will disagree with... ebay coil overs all day long. I'v had $3k suspensions and I've had $1k suspensions... to me the differences are not worth the extra money. I put them on my 996 last year and they feel great, cost me $1100 if I remember right and were very easy to install. I had a set of kw's on my audi tt a few years ago.. lasted two summers before 3 of them were leaking... those cost $3200 to each there own but for me...cheap stuff only breaks when its not takin care of. I was able to fine some that matched my paint as well I know some disagree but I've been wrenching on cars for 15 yrs now and I'm tired of spending money or "better quality" just my 2 cents
Brian
Brian
theboz (07-22-2020)
oh and in the event you want to put bigger rims on there one day.. coilovers will give you a little more room. I have 315/35/19 on my car and I have extra room
These look good for cheap...
https://www.ebay.com/itm/GODSPEED-GS...nZA:rk:14:pf:0
I've heard good things about Ceika coilovers but I have no direct experience.
https://ceika-store.com/collections/...ducts/cct1m614
This guy hits most of the highlights on a 996 - https://www.youtube.com/watch?v=5QCj6e90cJc
Oh and the color(pretty sure that green made my car faster)... I mean come on.. that's a match made in heaven lolol
The following 2 users liked this post by ttt123:
professorman (09-26-2019),
theboz (07-22-2020)
Thanks for everyones input. Any specific brand/type to look at? What are the pro's/con's of using a strut with the original spring, or using coilovers that have the strut and spring together (i believe that's correct?). Does anyone have a handy diagram or list of all the nuts/bolts/parts that should be replaced while tackling this job? I'm working on the fronts, and do not need to do the rears at this point...yet....Any input is greatly appreciated!
I'm hoping to get mine installed this Sunday if the stars line up.
Hey Bill, installation is complete. It was a long road though, and I learned a few things. I replaced pretty much every part in my front suspension. After I completed it the first time, my passenger front wheel would bounce over bumps...as if it was a basketball. I don't know what I did wrong or what the issue was, but I noticed the new strut was already leaking. It could've been a defective strut, or perhaps i installed them incorrectly. I got a new replacement and replaced the passenger's side again. Also, people told me it could've been an issue with my upper strut mounts. I bought a non-brand mounts the first time, but purchased OEM Porsche brand the second time. They look totally different and I think OEM porsche is the way to go for strut mounts.
It's been a couple months since I re-did the suspension and it drives great. Only issue I have is that it sounds like metal is rubbing together when i turn full lock. I'm not re-doing it again, and I don't think it's a big deal, but it still bothers me when I hear it.
Take your time and torque everything to spec...i did not torque and wish i did. It's an absolute DIY job though...don't be intimidated.
