996 Forum 1999-2005
What a day, now to figure out what's happening with the car
Old 01-04-2019, 01:30 AM
  #31
ThatSalesGuy
ThatSalesGuy's Avatar
Originally Posted by Ahsai
The power to the coils and injectors come from pin4 of one of the big round connector called x59/1, which connects to relay #2 (ignition/O2 sensor), then to fuse C2.
What if you remove relay#2 under the rear parcel shelf? Does the LED stays lit?
I will check that in the morning.
Your better bet would be to repair the harness or get a used set from ebay. A brand new one will probably be more than $1k.
I'll have to see how bad it is when I get the coil pack off and find the other end of that harness. Do you know where it might go and how easy it will be to get the harness out?
Old 01-04-2019, 01:57 AM
  #32
Ahsai
Ahsai's Avatar
It's a pile of spaghetti https://www.ebay.com/itm/Porsche-99-...sAAOSwJK9bhrkO
https://www.ebay.com/sch/i.html?_fro...rness&_sacat=0
You will need to remove the whole intake manifold to replace the whole harness.
Btw, get the wiring diagram here http://arma.free.fr/porsche/996/GT3/...01999-2000.pdf
The power comes from fuse c2 then to the ignition/O2 relay, then it splits into two branches:
- to the coils and injectors via x59/1 connector
- to the 4 O2 sensors via those rectangular red/grey locking connectors
Old 01-04-2019, 02:07 AM
  #33
ThatSalesGuy
eek, I was hoping it was in pieces, not a complete harness.
may look to get under there and see how bad it is and repair it connected to car
Old 01-04-2019, 03:07 AM
  #34
Ahsai
Ahsai's Avatar
The socket for the torx bolts should be E10 or you can use a 8mm 12-pt wrench in a pinch.
Btw, the x59/1 connector does cut all the wires to the coils.
Old 01-04-2019, 09:15 AM
  #35
MattBurns
MattBurns's Avatar
I would repair the harness. When we do engine swaps here at my shop with used motors I always keep the old harnesses and cut the pigtails off for this exact reason, you just never know when one plug can be the difference between repairing a harness inexpensively versus replacing a harness for thousands. In our area this past year rodent damage has been rampant, so we are seeing more and more harness damage. If you have a good Porsche independent shop in your area swing by with that plug, you might be surprised with what they have. Heck, every dealership I have ever worked for had a box of old connectors around for stuff like this, so might be worth swinging by a dealership and asking a tech if they might have a harness out back they cut up.
Old 01-04-2019, 10:01 AM
  #36
MattBurns
MattBurns's Avatar
NAPA lists the coil pigtail. Echlin EC506 is the part number. $63.00 retail.
Old 01-04-2019, 11:32 AM
  #37
808Bill
808Bill's Avatar
Get some rat traps set up and catch that bastard before it causes more damage!
Old 01-04-2019, 07:27 PM
  #38
ThatSalesGuy
Thanks.
looks like the only way to be able to get up and reach that pigtail and cut it off and solder a new one on is by removing the header
Old 01-05-2019, 01:03 AM
  #39
808Bill
808Bill's Avatar
Removing the header is not hard.
Old 01-06-2019, 01:03 AM
  #40
ThatSalesGuy
For sure
It doesn't, just a few bolts and ordering new gaskets.
the trying to attach a new pigtail looks to be challenging as there isn't much room to work with under there.
Old 01-06-2019, 10:16 AM
  #41
808Bill
808Bill's Avatar
I may have a harness.
Old 01-06-2019, 10:34 AM
  #42
ThatSalesGuy
the full one or the coil connector?
Old 01-06-2019, 11:28 AM
  #43
808Bill
808Bill's Avatar
The coil connectors
Old 01-06-2019, 02:50 PM
  #44
ThatSalesGuy
The coil connectors
if you do, that'd be awesome.
PM me and we can discuss
thanks
Old 01-06-2019, 04:33 PM
  #45
Kris Murphy
Kris Murphy's Avatar
I've got the full harness pulled from a 2000 C4 if you decide to go that route.
Quick Reply: What a day, now to figure out what's happening with the car
