996 Forum 1999-2005
New 996 Owner - A Comedy of Errors
Old 01-05-2019, 02:47 PM
  #31
Bash Hat
Bash Hat's Avatar
Not that I’m aware of but it’s not hard to do.
Pull the side mirror cover up and out (don’t disconnect any wires) you can leave it hanging. Remove int door handle (the black plastic piece). It pries off with a flat head screw driver. Remove the two torx bolts under the handle. One is longer than the other. Lift the door pocket arm rest cover and remove the small screw. Remove one more small screw from behind the silver door pull. You may need to pull it to see the screw. Now you can pry the door card off gently. Pop the clips. Lift up and out a few inches. Disconnect the 2 microswitch connections and the connector for the lower door light. Now you can set the card aside. Peel back the left side of the vapor barrier. Unbolt the metal bracket (goldish color) inside the door with the 4 bolts. This will give you room to get your hand in there. With a flashlight you can see the back of the exterior door handle. You should see a 3” metal rod that is meant to be attached to the lock mechanism and secured in place with a black plastic sleeve. If it popped out you may need to unbolt the handle. Two small nuts on the inside keep it in place. Removing these will let you wiggle the door handle out so you can reconnect the rod. That’s pretty much it. Just make sure to test it a few times before you Button it up.
Old 01-05-2019, 03:17 PM
  #32
Ahsai
Ahsai's Avatar
Check this out.
Old 01-20-2019, 10:58 AM
  #33
Sixfiddythumpa
Sixfiddythumpa's Avatar
Thanks Bash and Ahsai for the info. Dug into it yesterday and the repair was successful, though I struggle with the door latch cable after it had come undone. Also a addressed a loose mirror screw while I was in there. Can't wait for spring weather so I can get it back on the road.
Old 01-20-2019, 11:07 AM
  #34
Bash Hat
Bash Hat's Avatar
Good to hear you got it sorted.
Old 01-20-2019, 11:27 AM
  #35
Sixfiddythumpa
Me too! Next up...mufflers.
Old 01-20-2019, 12:24 PM
  #36
Bash Hat
Bash Hat's Avatar
Can’t go wrong with a Gundo hack 😁
Old 01-21-2019, 07:55 PM
  #37
IkoIko911
IkoIko911's Avatar
Originally Posted by wyovino
Always lock your car when parked in the garage or your battery will drain much more quickly.
two years of ownership, NEVER lock it when its in my garage, has never drained my battery
Old 01-21-2019, 08:19 PM
  #38
Bash Hat
Bash Hat's Avatar
+996. DON’T lock it when in the garage. If you leave the car for 5 days locked it’ll go into “sleep mode”. Remote won’t work to open the door.
Old 01-21-2019, 09:44 PM
  #39
808Bill
808Bill's Avatar
https://youtu.be/oa1lRbOktPY
I need this!
Old 01-22-2019, 10:24 AM
  #40
dporto
dporto's Avatar
Received 1,154 Likes on 791 Posts
Never lock your car when parked in the garage. The car goes into sleep mode after 5 days and if the car is locked the lock won’t respond to your remote. Always keep the car unlocked when parked in your garage.
^^This^^ is terrible advice, as your battery will drain far quicker without the doors locked. I think the proper advice is:
1) make sure your battery is fully charged
2) get yourself a battery tender and hook it up whenever your car is parked for more than a week at a time.
3) Make sure the emergency trunk/engine cover cables are accessible so when you need them you can reach them
Of course none of this helps you at the moment...
Old 01-22-2019, 11:20 AM
  #41
Bash Hat
Bash Hat's Avatar
Read above. He already got into the car. And we gave him the fix for his door lock issue.
I never lock mine while parked parked in the garage. Put it on a tender and you’ll never have an issue. It’s not terrible advice.
Old 01-22-2019, 11:27 AM
  #42
TexSquirrel
TexSquirrel's Avatar
Received 2,389 Likes on 1,266 Posts
Who can leave their 996 in the garage for 5 days?
I've got to drive mine almost daily or I get the shakes.
Actually if I'm leaving mine for more than 2 days, I hook up the tender and lock it.
Old 01-22-2019, 12:36 PM
  #43
RazorKQ
RazorKQ's Avatar
Yep, what Bill said.
Old 01-22-2019, 12:49 PM
  #44
RazorKQ
RazorKQ's Avatar
So, if you lock it while in garage it will go into sleep mode in 5 days. In sleep mode doesn't it use less battery? If in sleep mode then use the key to unlock the door and it comes out of sleep mode. What am I missing?
Old 01-22-2019, 03:40 PM
  #45
TexSquirrel
Only a problem if the key doesn't unlock the door since the passenger door doesn't have a key and you can't crawl in through the trunk.
Quick Reply: New 996 Owner - A Comedy of Errors
