Bought a 996 Today
#31
Ouch! Did not realize that was a wear item, or at least not at that low mileage. Did you have any warning before it broke?
#32
I don't think it is a maintenance interval wear item. After reading this I got worried and did a quick search and found this as reference: https://pictures.dealer.com/porscheo...4bfcf1cb92.pdf
#34
No warning whatsoever. Was cruising at about 25mph downtown, top down, second gear loafing when the most god-awful metal-against-metal sound I've ever heard erupted from the back.
I shut it down and had it trailered to my tech. The engine grenaded when the chain broke and the engine was toast. Nothing but chunks of metal in the pan.
Sold it to my techie for $4500 as a roller.
The car was in my family since new and perfectly maintained all its life. No warning, just utter and complete destruction.
#35
Which LN bearing are you going for? "The Solution" or just the standard retrofit kit (needs to be replaced again in the future)?
#37
Just doing the standard replacement LN kit. “The Solution” would be nice but realistically it will be a long time before I put another 75,000 miles on this car, so will just replace the bearing when I do a clutch again.
#38
Yes I know! I’m being a poor new member of this group but will correct that. Been on a week-long business trip to told the shop they could take their time on the RMS, clutch and IMS bearing. Should be picking it up this coming Friday and will post pictures! Not sure if i can get the seat fixed by then or not but all the other (minor) cosmetics should be good. Most are nothing a good wax and detail won’t fix.
#39
Jake said he's seen these fail at as low as 7000 miles. He attributes this to inferior manufacturing. He has better quality replacement chains that he can replace w/o an engine teardown.
#40
I was fortunate enough to find the remains of a chain roller when I dropped the sump cover for inspection soon after I purchased my 996. I sent it off to Flat6 Innovations to replace the chains and do some other work on it. Jake said I was very lucky that I decided to drop the sump to inspect. When they pulled them, *BOTH chains had a single roller missing. My Carrera had only 44,000 miles on it.
Wow. That is some kind of lucky. Will definitely have my Indy look carefully for chunks of stuff in the sump (I think he would anyway).
Had a few minor items not show up, so may not have it ready by Friday. That means I may not be able to play with my new car until after Christmas. Since I have to drive it from Chicago area to Columbus this time of year I will have to watch the weather carefully.
