Round Two - Water Pump and Tstat
Local Indy will be replacing original water pump and stat on my 20 year old 996 (64k miles) on round two of maintenance. Pelican states the Porsche pump has a composite impeller, Pierburg is metal (and $100 cheaper) and GEBA is composite and the same price as Pierburg.
I plan on keeping the car, and as both P and G are listed as OEM, not too worried about either one, unless someone can talk me out of the composite.
I’m embarrassed to ask this, but since I moved to FL, and it’s quite a bit hotter than PA, should I bother with the colder stat, or just forget it. Most of my driving is on relatively empty roads, not a lot of sitting in traffic. I know there have been extensive discussions about this one.
Composite impeller and low temp tstat. Easy peasy.
+1 for the low temp stat. Low Temp means the functional operation of the unit, not ambient air temp or environment. A low temp stat just means it will start circulating coolant through the radiators at a lower temp (sooner) than the stock version, definitely beneficial in warmer climates like FL
