Blackstone Oil Analysis report: How to interpret results
Blackstone Oil Analysis report: I don’t know how to interpret these results. Is anyone experienced in reviewing these?
It looks good to me, but I don’t know if there is anything that I should be concerned about. Is this report average, good, great, excellent etc.
Oil report
Oil report
Received 5,388 Likes
That's an OK report. It's just ONE report, so we don't know much. For example, are wear metals (Iron, copper, Alum, lead) going up or down? Keep doing the tests. And update in 2019.
Why are you using a 10W40? You don't want to use a 10 weight oil. You should use a 0 or 5 weight. So, 0W40, 5W40, or 5W50.
See how low you are in the spec range for viscosity? That's classic Mobil One shearing down. I suggest using Mobil's 5W50, and it will greatly improve, and is still A40 Porshe approved. Your wear metals should follow, with a slight improvement in 1 or 2 changes, and drop 1 or 2 PPM.
See this thread.....
https://rennlist.com/forums/996-foru...-analysis.html
There are a bunch a posts around 100 that have postings of the findings.....I am one of the last posts with four oil analyses, #199. Scroll up from there, but you can get lost with info in this thread.
https://rennlist.com/forums/showpost...&postcount=199
You also need to compare to equivalent oil.
My Driven 40 would not be a good comparison.
Originally Posted by professorman
Oil weight was a typo. It’s 0W40.
So do the trends is what is more important than comparison to similar vehicles?
