996 Forum 1999-2005
MK2 GT3 Wheels/5mm spacer question
Old 11-19-2018, 08:21 PM
85eurocarrera
85eurocarrera's Avatar
Originally Posted by dan_189
Australia, although I think there are some for sale in the US in the classifieds section.
I've been looking. Haven't seen any 8.5/11 x 18's.
Old 11-19-2018, 08:48 PM
dan_189
dan_189's Avatar
There were 2 sets for sale recently (within the last few months) - ones that were re-painted and a standard set
Old 11-19-2018, 10:37 PM
lowpue
lowpue's Avatar
I think for both 997 and 996....GT3 and Carrera bolts are the same...if you go with spacers on either you need to get red collar for either if using spacer. I don't think Porsche would screw with that convention for liability reasons. I would also never use a red collar without spacers. IF you want to make sure take a bolt and the wheel that is not mounted and see how much the bolt sticks out on the backside. they should stick out the same on either wheel.
Old 11-19-2018, 10:52 PM
dan_189
dan_189's Avatar
Thanks Lowpue, Autoatlanta and PET2 list the same bolt part number for the 6GT3 and Carrera but list the 7GT3 bolts as the +5mm version with the red collar.
I'm going to remove the spacers and +5mm bolts that i'm currently using and go with standard length
Old 11-20-2018, 12:58 AM
lowpue
lowpue's Avatar
That does not make sense....I would check with Porsche on this....I would find it unusual for Porsche not to standardize.
Old 11-20-2018, 01:30 AM
dan_189
dan_189's Avatar
Unfortunately as these cars get older I find that i'm informing my OPC with knowledge from this forum more often than they are informing me...
Check it out:
Carrera/6GT3 bolt part number: 996 361 203 00 - superseded to: 996 361 203 01
7GT3 part number: 996 361 980 00
Carrera: http://www.autoatlanta.com/porsche-p...section=601-00
6GT3: http://www.autoatlanta.com/porsche-p...section=601-00
7GT3: http://www.autoatlanta.com/porsche-p...section=601-00
Old 11-20-2018, 03:19 AM
dan_189
dan_189's Avatar
PET2:
Old 11-20-2018, 11:07 AM
DGI
DGI's Avatar
Would converting to studs be an option?
I"m planning on doing so, one less thing.
Old 11-20-2018, 04:08 PM
dan_189
dan_189's Avatar
I dont have any interest in using a stud kit - I don't have the need.
Also be weary of stud kits - someone on here had one fail on them
Old 11-23-2018, 09:23 PM
Splitting Atoms
Splitting Atoms's Avatar
I bought a set out of the rennlist classifieds a few months ago, probably the ones you are referring to as standard. They have some scuffs and imperfections, but they are fine for tracking. I had been looking for a while. I saw a couple of sets in England that were 7 1/2 and 11 which seems too narrow for the fronts. As previously stated, mine are 8 1/2 and 11.
Old 11-24-2018, 12:08 AM
lowpue
lowpue's Avatar
Here is a view of my GT3 wheels on NB with 5mm spacers only in the rear
Old 11-24-2018, 12:29 AM
Projekt EPiK
Projekt EPiK's Avatar
I have a 1999 C2 running the same set of GT3 wheels that you are looking at using. FWIW I'm running non standard tire sizes for personal reasons, with a thicker sidewall and have no suspension, or fender rubbing or anything. 245/40/18 frt on the 18x8.5, and 275/40/18 on the 18x11et63. Ride quality is excellent and handling doesnt suffer one bit btw.. keeping in mind that I'm DD'ing this car with this setup.. track will be different. I have just completed a 800 mile road trip to the Tail of the Dragon in the mts of TN, NC and GA though with no issues at all. My NB car is using Koni yellows and H&R Sport springs as well.
My rear fenders are rolled, and I have been considering flushing the rear out a bit more and using a 5-10mm spacer, although the look now is not bad at all. Check the "show me your wheels" thread in 996 for pictures if you want to see it, I'm at work right now and can't post any.
have fun with it
Old 11-24-2018, 12:31 AM
Projekt EPiK
LOVE IT!
Old 11-25-2018, 05:16 PM
dan_189
dan_189's Avatar
Thanks everyone, i'm now considering keeping the 5mm spacers on the rear because your car looks awesome lowpue, the rears look perfectly filled!
Lowpue do you think the 5mm spacers are required at the rear to match the additional offset of the fronts?
Just for some info on the standard 5 spoke vs MK2 GT3:
MK2 GT3
Front: 235 / 40 / 18 ET40
Rear: 295 / 30 / 18 ET63
MK2 Carrera 5 Spoke:
Front: 225 / 40 / 18 ET50
Rear: 285 / 30 / 18 ET65
So really the rear ET there is only a 2mm difference so + 5mm would make it 7mm in total vs the 5 spoke.
Also here are the tyre differences (the fact that the rims actually look like MK2 GT3 ones was a coincidence!):
Old 11-25-2018, 11:20 PM
lowpue
lowpue's Avatar
MK2 GT3
Keep in mind the GT3 wheel is 11" wide and I think the 5 spoke is 10" wide....so you actually have an additional 12.7mm offset....Thus the rear with 5 mm spacer is 20mm wider....if I did the math correct.
Quick Reply: MK2 GT3 Wheels/5mm spacer question
