Rear main seal leak signs?
What are the signs to be looking for. I just noticed a bit more than a few drops in my garage floor. I can’t get to looking until the weekend. If anyone has an undercarriage picture that I might compare as a reference I would appreciate it.
Received 1,091 Likes
Basically you will see oil dripping where the transmission and engine mate. Oil spots on the garage floor tell a lot. If the drips are dead center, just ahead of the engine, probably your RMS.
And just hope it's not your IMSB flange/bolts which should be addressed at the same time.
Mind posting the details/service history on the car? Has the RMS been replaced before? IMS?
The RMS and the IMS leak from essentially the same place when the transmission is attached to the engine. Without removing the transmission there's no way to tell which one is leaking (it's possible they're both leaking) unless you can figure out a way to get a bore-scope in there.
Just a quick reply. It’s a 99, with a dual row bearing. Neither the bearing or rms have been done. The car was babied by the previous owner. I have driven in much more aggressively. Wondering if I am shaking things loose.
Is this a 1 owner car (previous to you)? If not, how many previous owners were there? The fact that (you think) it's a dual row bearing doesn't really make a difference. Is there any possibility the the engine isn't original? If so, you can't be sure of the bearing type until you identify the engine - even then it's not a slam dunk until you've actually looked at the flange (some early 2000-2001 M96-04's still used the dual row bearing). We all wish there were some hard and fast rules with these things but...there are not! Of course none of this means your engine is about to explode, but you should definitely do some digging and find out exactly what you're dealing with before you make any assumptions. Good luck
The person I purchased it from was not the original owner. It has passed hands a few times. It was identified as a dual row from the engine number, it is the original. Again, info from the previous owner. I have dug into the service history and I am skeptical about a few things now. I will get under it over the weekend and then I am planning to take it to Specialist in Sealy Texas. I knew getting a 996 was going to bring maintained needs. I love the car and the exterior is amazing. But I am worried (much driven by the forum) I fear am may fall into a money pit. Lol. But I am a glutton for punishment.
It makes sense to do that. I did not know that about the dual row. From what I had read I was more secure about it than the well known ims. Yeah, it makes sense to do the bearing, AOS, RMS and clutch all while in there. It would give me some piece of mind.
not sure what I dread more...a failed engine or my wife saying...I told you so about buying an old car...ugh.
Consistent service history is the key.
Change the oil, cut open the filter and drop the sump to inspect. Send in an oil sample and start tracking it to see what wearing.
Then drive the hell out of it!
