Please help me identify headlight type - 996 Headlights
Rocky Mountain High
That’s really odd. Are you sure they weren’t added later? Headlight washers were a DOT requirement for HID headlights.
you are correct, they were taken off another 996.1 and installed on my 99 when I bought it. Was the headlight washer incorporated into the headlight or added on to the bumper cover for a Mk1?
Rocky Mountain High
It was in line with the turn signal, incorporated into the headlight. Factory HID headlights also have auto-leveling to prevent dazzling oncoming traffic at night. There are axle sensors for the leveling system.
I really feel like an idiot because I repaired the other headlight and it looks amazing. I just panicked over how the clearcoat reacted to the plastic and by trying to paint strip it instead of just sanding it I made things worst.
I sanded it back yesterday starting from 80 grit all the way to 3000. It isn't perfect (some deep scratches show), but the headlight is usable. I am definitely buying at least the lens to fix it.
I will take a picture as soon as I get back home... I have seats getting re-upholstered and I am going to start wrapping the entire trims since the previous owner replaced the original interior trim pieces with fake carbon fiber ones and they look hideous. Anyone has any ideas where I can buy aftermarket trim pieces... can't seem to find a place...
Thank you very much for your support! Much appreciated!
BTW, there aren't aftermarket headlights for the MKII 996... only MKI - that seemed odd to me. Anyone knows of an aftermarket headlight for the MKII?
Rocky Mountain High
Good luck with it; I hope you're able to restore it to your satisfaction. To my knowledge, you can't purchase the lens alone.
I haven't seen an aftermarket light for the MK II cars. The MK I cars shared headlights with the Boxster, so the market for aftermarket lights was much larger.
I've seen just the lens on eBay for around $100 before.
Call DC Automotive
http://www.dcautocatalog.com/illustr...ndex/966143513
Or keep checking eBay for headlights/lenses.
Be patient and you'll find them on eBay.
I waited and nabbed some xenon 996.2 headlights for $250 each.
One is for a Turbo, so I occasionally look for a matching headlight. (Turbo or Carerra)
Turbo will fit and work, it just doesn't quite match.
Call DC Automotive
I spoke to DC... they don't have anything in stock unfortunately. I am lurking around eBay and found some that are perfect, but they are broken (not the lens, but the headlight) and the seller won't accept anything less than 300 bucks. I might bite the bullet and buy some for about 600 bucks which is the cheapest I found on ebay... or I will lurk some more. The car isn't registered yet - awaiting for a clear title from the county and the seats are getting re-upholstered as of now. I bought a damaged seat that had a great frame and switch that worked, so from 3 crappy seats, we are making 2 good ones... otherwise, car is mechanically in order. Needs a good clay bar job and a polish... I am very excited to get to drive it.
Moerbeck, if you buy one off ebay, make sure you get the halogen type and NOT the HID (i.e. Litronic). Yours are definitely not the Xenon based headlights. The easiest way to look for used replacements is look for one without the headlight washers. For some reason, the Halogen type headlights for the mk2 996 didn't come with lens washers.
Yep - I bit the bullet and bought the broken one off of Ebay for $300. I will take a look at its condition and if it isn't terrible (it didn't look like it was terrible from the pictures) I will lightly sand and buff the lens and do a complete swap. It is what it is... I am taking the L and moving on Thank you for your advice... definitely buying the halogen ones. No Xenons for my car. I don't have a headlight washer and I prefer it that way anyways. Thank you once again!
They could be Porsche Techequipment models from dealer, I had them on my Boxster S, Dealer made me a good deal to get them out of parts inventory.
No washers as the Triangle was separate part number.
What does you Option code show, that is determining fact.
