Inlet manifold vacuum flap
Hi everyone!!
Just wondering if anyone has an experience checking the vacuum operated flap on the inlet manifold , I just want to check mines working properly, can I for example put my fibre optic camera in to the flap valve and rev the engine, should I see it operating or does it not work like that, have great throttle response low down the Rev range but seems to go flat higher up and thought it might be this ??
Any help would be great !!
I tested one on a Boxster recently with a mityvac.
Originally Posted by DBJoe996
Are you talking about the resonator flap? It is vacuum operated and certainly, by applying a source of vacuum you can check/test it for operation.
