CD 2 Radio Locked "OFF" is displayed
Disconnected doesn't help. Normally I connect my battery and CODE appears. Apparently I botched the code 3 times and Lock is the only display now no matter how long I leave the power off..
HELP
HELP
Received 1,090 Likes
Turn you key to the ACC accessories position for an hour with the radio on and then try to enter the correct code again. Disconnecting the power will do nothing. Make darn sure you have the right code or it will go into "theft mode" again.
Normally on the Becker radiso, you have to leave them one for an hour (with the car running) and then it should allow you to reenter the code.
oppps... looks like Joe beat me to the response.
