How do I reset the fuel gauge? 996
I made a mistake and refueled while running. Fuel gauge is off, ever since. I thought the owners manual had this info, but scanning through it , I can't find it. Do you guys know the trick?
Received 1,091 Likes
Never heard of this one before. You could do as described above, it might work. Or, disconnect the negative battery terminal for a short period of time, say 10 minutes, reconnect and see if that resets the fuel gauge.
I've been told by a Porsche dealer "there is no reset/re-calibration - you need a new sender"... whatever... I reset my trip odometer upon refill, and always refill around 200 miles
In my case, I've got a C4 (not sure if the OP said his is a C4 or not) which has the "saddle tank" (split tank to accommodate the front diff). Because of this, the sender is only in one half of the tank...The fuel level in the other half of the tank is "interpreted" by the DME based on the info it's getting from the sender. I'm not sure I understand exactly why or how the system was designed like this. All I know, is that I've tried all of the "resets and fixes" (emptying tank, refilling tank, removing battery etc. etc. etc...asking the dealer to re-calibrate etc...). Mine still doesn't work - It reads full when full, but only goes down to slightly less than 1/4 when empty - Almost like it's calibrated for liters or something (don't know why it would be as it's a US car). Once again - whatever! If this is the worst of my problems, I'll deal with it the way I have been for the last 3.5 yrs.
Have u changed the sender or pulled it and done a test outside the tank. Its not that hard. I suspect there is something wrong with the arm or sender itself. I have had floats go bad and other issues on other cars do to age and rough roads.
I had to reset my instrument cluster on an almost empty tank on my C4 (removed the screw and disconnected the harnesses). The gauge was off on restart. I filled the tank to the max and reset the cluster once more. The gauge reset to max. Fixed.
Why would you refuel with the engine on? Didn't want to put your cigarette out?
MauiCliff (07-22-2022)
This is a known issue. There was even a TSB on it. My car had the sender replaced at one point, yet my fuel gauge has always been off (it never shows more than 7/8th of a tank).
There are a few threads out there on this if you do a search.
You could run the gas tank to pretty much empty. Then pull the battery for 10 mins. Then power it on and fill it up.
Found a reference in the 996 Essential Companion (author: Adrian Streather) about an issue with the fuel level senders in pre-model year 2001, 996 Carrera 4 and GT-3 models. There is a potential problem with the fuel level system if battery power is lost for any reason and there is less than 5 US Gals of fuel in the tank. When the power is restored the fuel level reading on the instrument cluster will be incorrect or even deleted. If the fuel tank has less than 2.6 US Gals the low fuel level warning light will not function either. The only solution is to fill the tank to full to force the fuel level measuring system into an accurate operating range. Apparently the fault was eventually rectified by a software update to the instrument cluster.
"All I know, is that I've tried all of the "resets and fixes" (emptying tank, refilling tank, removing battery etc. etc. etc...asking the dealer to re-calibrate etc...). Mine still doesn't work - It reads full when full, but only goes down to slightly less than 1/4 when empty"
^^ Once again...with emphasis this time! ^^^
** I haven't pulled the sender out yet...if anything, that will be my next try...
