Fuel Line Quick Disconnects in engine bay...
I'm still working on my engine swap - slowly...
anyway, how does this disconnect actually disconnect? Does the collar rotate? Or is there some other way to separate the lines? Both my 996 and my donor 997 have the same disconnect.
https://cdn4.pelicanparts.com/techar...arge/pic14.jpg
Rotate and pull if I recall (seems like forever since I did mine) correctly. It should be detailed in the tech article.
no tabs to push on this one. i'm reluctant to force it but it must be some rotation to separate the parts. It's a Raymatics part, maybe i'll call them on |Monday.
Mine is the pinch and pull as Ahsai described. Real simple once you get a grip on it.
Haha, thanks. Just hate to see someone destroys that $5 connector and found out it comes with the two fuel rails from Porsche as one piece ($400+).
I apologize for resurrecting an old thread, but I just want to say thank you. I could not figure this connection out, and this thread saved me. There IS a tab, it's recessed into the back of the connector, it doesn't feel like a tab, but it's there.
Thank you, thank you, thank you.
808Bill (08-04-2019)
