Airbags warning light - delete!
https://www.ebay.com/vod/FetchOrderD...=2454496573017
Took 4 days from germany and worked for the seat belt tensioner issue i had. One of the other ones has pins that just plug into the airbag harness plug but mine were missing so i got this sryle. Fyi the yellow connectors suck, i soldered them in.
Awesome, thank s@De Jeeper - found them and they are on order. Do you know if the seat delete plug works for a 987.2 Cayman?
I assume but dont know for sure the resistance for an airbag sensor is standarized so probably?
All of the air bag components can be coded out with the correct scan tool .No need for resistors. The air bag module stays in place and the air bag light will illuminate for the required bulb test.
EASY Replacement of "PASSENGER AIR BAG OFF" light
It turned out to be easy for me on my 2011 Cayman Base. After shearing off the top of the old indicator with a wood chisel I pushed it down. Then after lifting the shift boor cover I was able to reach in and unplug the old indicator.. Then pushed the wire and connector back up through the opening and connected the new indicator. Pushed the connector into place and all is working and new. Hope this will help others.
