How to remove seat adjust levers?
It's been a while, but I think you just pop them off. There are small phillips screws holding the panel on.
I'm almost certain you can wedge them off with a trim tool. It's probably easier if you remove the assembly by removing the small phillips screws and wire harness.
Here is a good thread that shows what is underneath the ****.
https://rennlist.com/forums/996-foru...placement.html
The plastic piece behind them comes off by sliding along the seat before you pull it away. If memory serves me correctly, there are 2 phillips head screws and then it slides straight up - then off. I don't think you need to take off the adjusters before removing the trim piece that they're attached to, so that may make your job easier.
