ABS, PCM Fault code 4205, front left speed sensor
These are taken at the ABS control module harness in the trunk, sensors are plugged in at the wheels. Yes, I should have measure 31 and 30 instead of 19 and 30..
Short to Ground
15 was .030V, front right ground
16 was .024V, front right signal
12 was 11.6V, front left signal
28 was 11.6V, front left ground
14 was 11.4 V, rear left signal
29 was 11.4 V, rear left ground
30 was 11.0 V, rear right ground
31 was 11.0 V, rear right signal
Short to B+
15 was .001 V, front right ground
16 was .001 V, front right signal
12 was .289 V, front left signal, was much lower before. I think this is supposed to be less than .3V based on step 5, but I changed to a better multi meter.
28 was .289 V, front left ground, was lower before.
14 was .271 V, rear left signal
29 was .271 V, rear left ground
30 was .293 V, rear right ground
31 was .293 V, rear right signal
Looking at the wiring diagrams shouldn't all the pins have similar measurements?
Short to Ground
Short to B+
I take that "Short to B+" is test step 5? How about test step 6 - short to ground (measuring resistance)?
Per the wiring diagram, if the abs side is unplugged, all these pins are only connected to the sensors and should not be connected to ANY part of the electrical system of the car. If you measure something close to B+ voltage on these pins, you have a short somewhere.
Yes Short to B+ is step 5.
Did step 6 again
12 was 4 M ohms
28 was 4 M ohms
All others were infinity.
Going to check all again. Really appreciate your input.
Did step 6 again
12 was 4 M ohms
28 was 4 M ohms
Can you do step 6 with the left sensor unplugged and see if that makes a difference? Also check post #18 above.
Unfortunately I'm as confused at this point because those pins should "float" if the abs side is disconnected. They should have no voltage.
Ok will do, but right now I can't pull sensor right now.
DON"T GIVE UP!
I cut wires for pin 12 and 28 at the joint created with new Porsche harness to see if voltage changed.
The new repair harness is somehow showing 11.6V between end of wire for 12 and 28 in the new repair harness and + of battery. Only wires left there would be for brake wear and wheel carrier ground.
Could 12 and 28 be shorting to ground through sensor to wheel carrier then to ground?
DON"T GIVE UP!
DON"T GIVE UP!
DON"T GIVE UP!
I replaced the wheel speed sensor. Had to drill out the old one, came out in pieced of plastic, magnet and copper wire.
Voltage readings for 12 and 28 are now the same as 15 and 16.
Hoping the PSM / ABS light would have turned off automatically....but it didn't.
Still not sure why rear readings are different than the front.
So measured all the pins again, with sensor plugged in
Step 5, short to positive. Multimeter set to measure volts between pin and negative battery terminal
15, 16, 12, 28 all measure .010 V
30, 31, 14 29 all measure .528 V. Will have to see if this changes with rear sensors unplugged.
Step 6, short to ground. Multimeter set to measure M ohms between pin and negative battery terminal.
15, 16, 12, 28 all measure over load.
30, 31, 14 29 all measure 8.1 mega ohm. Will have to see if this changes with rear sensors unplugged.
Short to ground. Multimeter set to measure volts between pin and positive battery terminal.
15, 16, 12, 28 all measure .100 V
30, 31, 14, 29 all measure 11 V. Will have to see if this changes with rear sensors unplugged.
Before I changed the front right sensor I was measuring 11 V for 12 and 28 to positive battery terminal. I wonder if both rear sensors were messed up somehow when the harness was damaged?
I think I may just pull the rear sensors and replace them.
So I replaced rear sensors. All measurements appear to be normal now. Unfortunately, abs psm lights are still on. I am not sure if they should automatically clear or need to be cleared with software.
