2002 C4 6 Speed - Transmission Won't Shift to R, 1, 3, or 5
This morning while getting onto the freeway, I shifted to 3rd only to be greeted with the engine hitting the rev-limiter and a loss of acceleration. Once I'd safely merged with traffic and I could try going through the gears a bit, I found I can't access any gears that require the shift **** in the forward position. The shifter moves into position, but it's mushy and obviously not engaging anything w/ the transaxle. Any suggestions on where to start looking? Thank
Cable probably popped off trans connection. This happens a lot as the clip gets brittle and snaps. Simple re-connect and zip tie in place.
Those clips SUCK! The zip ties are the remedy...
Those zip ties on those clips should actually be a Porsche part number. Running a manual trans car without them is just asking for trouble, usually at the worst possible time. Plus, it's not often that a 5 cent piece of plastic will fix your 996. Of course if they had a Porsche part number on them, they would be $19.95 each.
But did the put the factory retaining clips back in?
That was our agreement, but I haven't been under the car since I bought it about two months ago, except to troubleshoot a rattling exhaust tip. If the factory clips are missing now I have no way of knowing if he did or didn't.
If the cable slipped out, just put it back where it belongs and... You guessed it - Zip tie it !!!
If you happen to already have safety wire pliers, it is another alternative to the zip ties that may be more durable. I use safety wires in place of zip ties in this area.
Then get under there and check it out! It's not hard to check...
Zip ties are a lifesaver literally. The control rod on USCG Jayhawk came loose and we used zip ties to secure it. Had to as we just received mayday during crab season on the Bering sea. 6 fisherman saved.
