964 RS Engine mounts
#47
Seems ok but I do think because of the lack of the 150x150 square locating section that the RS mounts dont have the bolts can skew slightly. Not sure if I need to have another go at aligning them?
#49
It would, also the bolts I have arent fully threaded too eek, wouldnt be such a bad idea though. I do have some longer M12 x 1.5 10.9 grade fully threaded bolts.
The requirements are difficult to meet because they need to be 150x150 in size M12 1.5 pitch
Have you had any issues with your mounts being slightly off centre? Or is this just how they are?? TBH to anyone thinking about the 964RS mounts you're better off with the VEVO or RSS for simplicity
Bash Hat (11-29-2019)
barbancourt (10-19-2019)
#55
Readjusted and got the mounts to be slightly more centred but without the square retaining nut the bolt goes where it wants to
Letting this go!
Thanks all
Letting this go!
Thanks all
#57
The concave washers are upside down in this picture. The edges should turn up from the mounts, not down into the mounts.
#58
With the choice of which way to put the gold cup washers, I understand there is no wrong way, cups facing away from the rubber for more compliance, cups "cuddling" the rubber for more control. Even both cups facing up, or both cups facing down, there is a range of "tunability" to the setup.
The other point is, there is a Porsche technical bulletin detailing a change to the "flat" washers. (updated washer 12.7 x 45.5 x 5
999 025 091 02)
These have been upgraded to a much thicker and larger outside diameter for better support of the cup wsher. Probably to combat permanent bending distortion of the gold cup washers from a high G event, such as a canyon sized road dip, or a rally worthy jump.
But seriously, who jumps their Porsche these days?
999 025 091 02)
