Upgrades/mods for C4S?
Also - a few other people have mentioned color matched bumperettes. There is a forum sponsor called bumperplugs that sells these already painted to match and you just send in your old ones. I ordered front license plate hole plugs from them and they matched perfectly. They also offer color matched center consoles - which look really sharp IMO.
Its not super difficult - but its definitely a project. Technically you can reverse it without any additional parts - but it would require some thorough clean up of the inside 'cup' of the outside CV housing.
All great suggestions. I've been looking the Fister mufflers for a while now. How much of a PITA is it to remove the mufflers? Is it an all weekend ordeal or just a few hours and a few f-bombs? Since a lot of my time is on freeways, do you get a "drone" from when when driving freeway speeds? I replaced the engine mounts late last year so that one is done. I'm not too concerned about he bumperettes other than I'd love to remove them completely since I think they really take away from the back of the car so if anyone knows if that's a possibility I'd love to hear about that. I like the AWD system since my commute can sometimes put me in icy or snowy conditions and I like having 4 wheels keeping me on the road. The car was ordered with the carbon trim option, so one day I'd like to get the carbon center console, but that's more of a "like to have" than a need to have. Upgrading the head unit has also been on my wish list, but I have the Bose system so I've read that if I really want to get some good sound, I'd have to remove all of it since the components don't play well with aftermarket systems. Plus... I get so much road noise I don't know if I could really appreciate the sound quality in the end anyway.
So... I think I'm leaning towards Fister. clear bra, and/or suspension components upgrades. I'm taking the car in today to see what's up with the front suspension so that may determine where I go with all this.
Since you asked
Drop the bumperettes off at a body shop to have them done in body colour.
Motor mounts make a big difference. Your choice, consider them a wear item.
Wheel spacers 7mm front and 14mm rear.
Ti lugs from World Motorsports.
Short shift kit.
Lightsavers.
If still in the budget...
Fisters if that's to your liking.
A Denison Gateway for bluetooth.
Obvious bias
Short shift kit.
Lightsavers.
Obvious bias
https://www.bumperplugs.com/index.ph...product_id=163
The clean Euro rear bumper is my choice but sourcing shipping and painting add up quickly.
This is exactly what I did to mine when I removed the AWD from mine. When I reinstalled it a year later before selling it, the hubs were just as clean as when I removed the axles. And this was after a year of daily driving in Seattle on a car that never saw a garage. Just make sure you put a nice thick coat of PlastiDip on there (read:several coats).
OP-I installed an Alpine unit with BT and it works perfectly well with my Bose system. Even the faceplate blends fairly well. You are on point with the muffler/cat and suspension upgrade priority. Of note, I only turn on the head unit for BT. The car sounds so good it’s all the music I need.
A friend of mine just put CEIKA coilovers on his C4S and hes pretty happy with them.
For a street car and to make it just more fun to drive (and if you ever wanted to do a HPDE) the following are the best bang for the buck:
- Fister Exhaust (its quite literally 'just' right)
- EVOMS CAI (its the only one that actually does bring cold air in) - this is a sound mod - probably no real performance gains
- H&R lowering springs (the sport springs)
- ECS wheel spacers (7mm front, 15mm rear)
- LED interior light bulbs
- Numeric Racing short shift kit - it's head and shoulders better than the others and still maintains complete OEM looks
- Semi solid motor mounts (improves the feel by 1000)
Sorry - see above. Also - these will fit your budget easily.
The EVOMS is $300 and comes up in the classifieds pretty often
Get the Numeric on special or get a showroom floor model
Gundo hack can be done super cheap at any exhaust shop
Lowering springs aren't much - $400 or so but there is labor unless you want to do it yourself
I’d also invest in some Light Savers, the replacement taillight clips. Found one of my taillights hanging on by one screw and the OEM clip completely coming apart during a car wash. Probably had been like that for a while and was ready to break completely. Bought them from Pelican.
