New Tire and an alignment...
I have owned the car since Jan 17 and have put on almost 8K miles since I bought it. Last tire change per service records was at 95,000 miles. Rear Michelin PS2's were shot, fronts were still good. I don't track the car and figured I really didn't want to spend 1400 on a new set of PS2's or 700 on just rears so I went with the Sumitomo's based on some reading here and elsewhere. $532 shipped and $83 to install them with a %75 visa coming my way for buying four. 285/30/18 fronts 225/40/18 rears. Anyway, the left rear had some uneven wear so I had an alignment done. Turns out the car was out of spec just about everywhere. For the experts, how bad was it prior to having it aligned? Cheers guys and thank you!
These cars will wear the insides of their rear tires, that's normal. Eliminating that would require very little rear negative camber and toe-in, both of which would have some pretty unfavorable handling results. Is there a reason you're running zero negative camber up front? The more front negative camber the better with these cars. Front toe-in will help with straight line stability, but IMHO it dulls steering response, especially when you're lacking negative camber. Who aligned your car?
