996 Forum 1999-2005
Ramps suggestion
Old 05-17-2018, 12:14 PM
mlee2122
mlee2122's Avatar
i bought a pair of these steel ramps off ebay last year for under $229. I was a little skeptical at first but once i got them and really checked them i'm very pleased with them. I like the ability to use the hydraulic jack and get maximum height when the extra space is needed while it's already on the ramp. It has locks pins on the lift so it's extra secure. The ramp is also long enough that my lowered Porsche has no problem backing up onto the ramp. However i do have couple 2x that i put into the top platform so that my 315 wide tires sit confortably on the platform.
Old 05-17-2018, 12:30 PM
indymcsc
indymcsc's Avatar
Whoa, those are cool! Do you have a link?
Old 05-17-2018, 12:54 PM
mlee2122
mlee2122's Avatar
when i bought them last year they were $229..... these are the closest i've found. price went up but still not bad considering shipping is included. these are made of heavy duty steel so it's very sturdy.
https://www.ebay.com/itm/Hydraulic-V...IAAOSwFLBaYOTH
you can also google "steel hydraulic car ramps" and you'll see a lot more options....but these where the best priced.
they're also sturdy enough that while i had the 996 on the ramp i was able to put a car jack under front and raise the front end up to put on jack stands.
Old 05-17-2018, 01:13 PM
indymcsc
indymcsc's Avatar
Thank you! They look really sturdy. Are they hard to store?
Old 05-17-2018, 01:32 PM
mlee2122
mlee2122's Avatar
not really...never really weighed them but they're like 25-30lbs each. it's not that heavy to move around. It's painted and so it's possible to store outdoors but i keep mine in the garage. I have a section under my work table for ramps, floor jacks, jack stands, etc.... that i keep it at.
the only little awkward part is the pumping of the bottle jack. the top bar of the ramp gets in the way of full pump motion. so you only get like half the movement with the pump rod due the upper crossmember of the ramp getting in the way. I just use a smaller rod to pump the bottle jack with. But that's only a minor incovienence considering how seldom i use the bottle jack. . the standard ramp height is more than enough to do oil changes and checks on suspension components, etc..... like i said before it's just nice to have that option to raise it when you need that extra room under the 996.
Old 05-17-2018, 01:55 PM
indymcsc
indymcsc's Avatar
I really appreciate all the insight!
Old 05-17-2018, 09:21 PM
SoCal911t
SoCal911t's Avatar
Received 1,341 Likes on 658 Posts
The race ramps look a little easier to get the car up on. Thanks!
Yes, that's another good feature. Also, if your car is super low, you can get longer sections that make the approach even more gradual.
This pic (not mine) shows the 72" version.
I went with the 56" version but even the e30, which sits lower than the Porsche has no problem clearing them.
Old 05-17-2018, 10:05 PM
gcthree
gcthree's Avatar
Location: Williamsburg, Virginia by way of Garden City, New York
Originally Posted by JimmyB
Liftbars. I just love my liftbars.
I have a set from my 928. Do you need to jack the car first to block-up the wheels and enable you to get the liftbars underneath?
Old 05-18-2018, 10:41 PM
su8pack1
su8pack1's Avatar
I use the Race Ramps and a set of homemade ones.
Old 06-25-2018, 05:37 AM
yaknart33
yaknart33's Avatar
I have used the Rhino Ramps for about twenty years and works good .I do use jack stands when ever I have a car on ramps or hydraulic jacks .My only problem was the ramps would slide ,I made a 2x4 brace to the work bench that works good. Never saw a damaged Rhino Ramp.
Old 06-25-2018, 06:30 PM
Gptoyz
Gptoyz's Avatar
I have rhino ramps, had them for years, but I have an original formula - haven't had any complaints.
However...if I didn't, I would get these:
https://www.evasivemotorsports.com/m...iABEgLSLvD_BwE
unlike the race ramps, they have a grove for the tire to sit in and potentially not roll off of it
get 2 sets and roll right on to them!
Old 06-25-2018, 10:27 PM
808Bill
808Bill's Avatar
I also have used Rino Ramps for many many years. I like the two piece Race Ramp though as you can take away the first section to set a jack or jack stand for safety.
Old 06-25-2018, 10:42 PM
996AE
996AE's Avatar
Received 1,449 Likes on 956 Posts
I have never, not once heard of a single rhino ramp failure.
I use them with no secondry support.
Safeplace crowd advice; pay for for service
Old 06-26-2018, 02:52 AM
808Bill
808Bill's Avatar
Quick Reply: Ramps suggestion
