996 Forum 1999-2005
Tick / grinding noise at 0.36x crank rpm.,
Old 05-15-2018, 11:18 AM
User 63031
User 63031's Avatar
Default Tick / grinding noise at 0.36x crank rpm.,
My engine (3.4) developed a tick/grind noise especially when cold. It’s audible in the cabin as well as under the car. At 780rpm idle, the tick seems to be 290rpm. Definitely not 0.5x crankshaft, but slower (i can tell cause i also havea noisy lifter everynow and then, definitely the lifter is faster.
I’d upload the soundbite but my iphone doesnt let me.
Ratio to crank seems to be 0.36:1, anyone have an idea?
Old 05-17-2018, 07:01 PM
User 63031
User 63031's Avatar
Seems like this topic only got approved after it was well and truly buried. Anyway, I figured out what it was by carefully listening to the tick.
listened and recorded the sound, measured the periodicity of the grind and determined it to have a 'frequency' of 316 RPM.
Now, nothing in the car syncs up with 316 RPM. Idling, my engine runs 780 rpm. Camshafts go 1/2 that, so 390 RPM. The IMS shaft goes 0.67x crank, so 523 RPM. Couldn't think of anything else spinning at this weird fraction, until it hit me; the ***** in a bearing go 1/2 the speed of the races, while the ***** also have a shorter distance to travel because they're on a lower radius (more towards the center, smaller circle than the outer race), so complete 1 revolution 'faster'.
Correcting for the lower circumference the ***** have to travel compared to the outer race, which is a factor 1.24, I came out on the ***** inside the IMS bearing rotating with a frequency of 523 (shaft RPM) divided by 2 (***** go twice as slow) times 1.24 (distance in travel between outer race and ***** itself) = 324 RPM. Which is very close to the 316 I measured from the sound.
So it's the IMS going. Sounded like this:
Old 05-17-2018, 07:37 PM
Chris(MA)
Chris(MA)'s Avatar
Maybe buy a cheap stethoscope to localize the place where the sound is coming from?
Old 05-17-2018, 07:39 PM
User 63031
User 63031's Avatar
Well I already solved it, it was coming from the IMS and the periodicity of the sound corresponds to the rotation rate of the ***** inside the bearing which is unique in the motor. Nothing else spins at 324 RPM. I just figured I'd post back with the results for anyone looking for it in the future I'm pulling it apart as we speak.
Old 05-17-2018, 08:06 PM
Chris(MA)
Chris(MA)'s Avatar
Gotcha, I didn't know if you were 100% sure or not. Its an interesting way to check for the source of a noise; I wonder if there is some kind of phone app that can spit out the frequency or period of a repetitive clicking or tapping? could be used by others on here to trace the source of noises?
Old 05-17-2018, 08:08 PM
User 63031
User 63031's Avatar
Haha, that's exactly what a friend said who was in my workplace with me when he saw me crunch the numbers after making a spectograph of the sound on my PC. "There must be a way to make an app for that, "IMS Failure Detector" or something".
Haven't found one yet, but sure would be useful.
Old 05-17-2018, 08:34 PM
fpb111
fpb111's Avatar
Makes the same sound with the belt off? How did/does the oil filter look? Almost sounds like a water pump grinding against the block.
Old 05-17-2018, 08:36 PM
User 63031
User 63031's Avatar
Yeah I started it with the belt off, suspected the water pump at first. Same sound. Ferritic metal grit and larger debris (1-2mm) in the filter which is only 300km old. All pretty clear :P
Old 05-18-2018, 10:39 AM
Paul Waterloo
Paul Waterloo's Avatar
Wow....good catch, I think? Do you have the spin on adapter or the OEM filter? What year is your car and how many miles?
Old 05-19-2018, 10:23 AM
Horsepwr
Horsepwr's Avatar
I can't believe you ran the car that long hearing that noise. Shut it down and tow it to the shop. Sounds like a bag of marbles in there, which coincides with your IMS theory. Side note, nice work on the math, detective. LOL
Old 05-19-2018, 10:29 AM
User 63031
User 63031's Avatar
Should have been more clear about that; the vid is not mine but someone elses. I linked it as it's the same sound. Car's been stationary after hearing the sound, and is not going to be started before the IMS is fixed.
Old 05-19-2018, 10:32 AM
Horsepwr
Horsepwr's Avatar
PHEW LOL. Well I can't believe that guy ran his car sounding like that. Every rotation is damage. 780rpm Idle, almost a one minute video, he basically was taking a hammer and chisel to his motor 700 times to post that lol. Not smart.
Old 05-19-2018, 10:42 AM
Mike Murphy
Mike Murphy's Avatar
Received 1,580 Likes on 987 Posts
Interesting. Let us know what you find. The video (while not yours) kinda sounds like 1/2 crank speed to me, or at least I would have assumed that. I would never have figured out 1/3rd RPM like you did. If you tear the whole thing apart and it’s the IMS, let us know.
Old 05-19-2018, 10:57 AM
User 63031
User 63031's Avatar
Definitely will, should be coming out this week. But I am really confident in this analysis :P
I went all Audacity on my recorded soundfile, and got the frequency from the spectogram. But if you tap along with the vid here, you'll get a general measurement of how many beats per minute (= rpm): https://www.all8.com/tools/bpm.htm
Old 05-19-2018, 12:45 PM
Coopduc
Coopduc's Avatar
Based on the sound alone, I would have guessed connecting rod bearing.
Quick Reply: Tick / grinding noise at 0.36x crank rpm.,
