What are some of your mods
Another self confessed spreadsheet keeper...
One for maintenance one for modifications, some of which include:
Ipd plenum, cargraphic mufflers, LSD, dension gateway 500, cargraphic UD pulley, non smokers kit, 997 shifter and SOFA
1. Fister Exhaust
2. Porsche short shift
3. Leather center console and ignition bezel (Exclusive Option)
4. Aluminum gauge rings
5. Aluminum pedals
6. Sprint Booster throttle module
7. GT3 front spolier lip
8. ...............
5. Aluminum pedals
8. ...............
Some of these are Fixes, not mods per se' but here goes...
1. EPS - Front Coffin Arms (with replaceable ball joints) and Lower control arms (tuning forks)
2. Bilstein B8's with H&R sport springs
3. Tarrett front camber plates/Top mounts
4. H&R 3 way adjustable sways
5. Tarrett adjustable drop links
6. Front wheel bearings
7. Stock Motor Mounts
8. Function First Transmission insert (black)
9.3 spoke steering wheel/airbag
10. Aluminum Pedals
11. Numeric Racing Shifter and Cables (after doing 997, and B&M ssk)
12. New water Pump (Pierburg)
13. New AOS (stock Porsche)
14. Low Temp T-stat (LN)
15. New Vacuum lines
16. New Cam Chains and Cam chain tensioner pads
17. New Timing chain tensioners
18. The IMS Solution (with pressure oil feed and spin on oil filter adapter)
19. Magnetic Oil Drain plug
20. Center Radiator
21. Ignition coils and Spark Plugs
22. Clutch kit (Luk/Sachs)
23. Brake Rotors and Pads, wear sensors (Meyle)
24. Leatherworld leather repair (steering wheel, drivers seat bolster, shift boot, parking brake handle and assorted other little places)
25. A few coolant hoses
26. Headers (Agency Power)
27. Fabspeed Mufflers (Maxflo - Came with car, but I suppose they'd be considered a "mod" - I didn't put them on though)
28. Body work - This past winter I cut out a bunch of rot/corrosion I found in front of the rear wheels (beneath the plastic wheel well liners and the corner trims) and welded in new steel and re painted).
29. Coco Mats - floor mats
30. Carrera Decals 3" silver Porsche script side stripes
31. Passenger side window regulator (URO - has been great so far, 1 year in)
32. Tarrett Under-drive Crank Pulley
I'm sure there are a few other assorted items I'm leaving out, but you get the gist of it. I've done a Sh*t load of work to this thing in the 3 and a half years I've owned it and I'm loving every minute of it.
10. Aluminum Pedals
20. Center Radiator
Just off the top of my head....
3.4 to 3.8 conversion
OS Gikken LSD transmission
Ohlins coil overs
Complete monoball everything by Tarrett
Wevo motor mounts
Solid trans mount
Fabspeed Maxflo mufflers
PFC brake pads
GT3 master cylinder
Motorsports AOS
3rd radiator
Catless X pipe
OMP Carbon fiber full halo driver seat
OMP WRC passenger seat
RSS roll bar
OMP wheel with Sparco adapter and quick release
Rennline floor boards
Numeric Racing shifter
Ohlins coil overs
Wevo motor mounts
Solid trans mount
PFC brake pads
GT3 master cylinder
Motorsports AOS
3rd radiator
Catless X pipe
RSS roll bar
RSS underdrive pulley
IPD competition plenum with larger TB
Resonator delete
200cell kats and Cargraphic mufflers (great sound!!!)
FVD X51 style larger oil pan + skid plate
magentic oil plug; spin on oil filter adapter;Bilt Racing washable oil filter
Stainless steel brake lines and Castrol SRF brake fluid
Ferodo DS2500 brake pads
Ohlins R&T suspension
Powerflex purple suspension bushings
LED tail lights
Resonator delete
LED tail lights
An underrated mod is adding this relay to add the 3-blink (actually 4-blink) turn signal functionality that most newer cars have:
https://www.ecstuning.com/b-genuine-...er/000998229a/
$50 and an afternoon to add a feature you'll use every day.
Also upgrading the cigarette lighter if you haven't already. Mine was the wrong diameter to fit most modern things; they fit loose and made bad contact. Replacing with the 997 part fixes this.
Painted center console is one of the most dramatic interior mods if yours is a drab color and/or worn.
