Upgraded shocks with OE springs (liveability questions)
5th Gear
Hi all!
I'm the owner of a daily driven, 2002 C2. I commute in this car. Generally 2 hours a day round trip, mostly highway. I addition to this usage, my wife has recently discovered the joys of autocrossing. And that's where my question comes in.
We'd like to stay in the basic street class, which allows for the shocks to be changed out, but not the springs. Does anyone here have any real life answers about a combination therein. Both in how it performs under performance driving, and for my daily commute? I was looking specifically at the Bilstein B6s, or B8s. I'm assuming the former are the way to go since lowering springs won't be added. But I'd love to know if anyone else has gone this route and what I might expect, or what a better option for this use case might be.
Picture of the car in use added just for fun.
Thanks!
Thanks!
You may look into the ROW M030 option. Porsche factory suspension. Around $1500 shipped (w/M030 sways) from Suncoast, Design 911 and a couple others. I love my set-up for the flexibility and liveability.
5th Gear
Thanks. I've looked at that, but I can't switch to the Euro suspension without changing SCCA classes. I'm likewise only allowed to change one, but not both, swaybars.
Received 1,085 Likes
After a bunch of research, I went with the Bilstein B6 on stock springs and have been very pleased with the result. I don't autocross or race the car, just everyday daily driver. And it is comfortable without being harsh or firm riding.
I believe my '99 has the original shocks it was born with. I'll be changing them out this winter along with a brake job. I'm wondering if it necessary to replace the springs with new OE spec. ones or leave the originals.
5th Gear
I just got the Koni FSD shock kit. They have a rebate of $50 until the end of May. Best price I could find was here:
https://www.tunersports.com/koni-fsd...10_p25209.html
I'm using the stock springs and sways. It uses the same kind of valving that high end shocks like Ohlins use to soften up over large bumps and remain stiff in corners.
Very comfortable to drive everyday on normal roads. Better than the OEM shocks. Noticeable better in the corners, but I haven't had a chance to autocross the car with the new shocks yet.
I can't say whether the B6 are stiffer or better for autocross. You can definitely find much stiffer adjustable shocks (racing shocks) that would be better if you were very serious about autocross, but I wouldn't want to use them for a 2 hour drive each day.
I'm happy with the Koni FSD and if you aren't getting lowering springs, I think they are the best choice.
How does it compare to the original oe combo? You say it’s not harsh, but is it at all noticeably firmer than before even with the stock dorings still in place? Less lean? Or is it just the same? I guess I was expecting the B6s to be a bit of a performance upgrade over original, while still being comfortable enough to live with everyday.
I went with the B4 because my 65 yr old a$$ needs coddling and for me I have no intention of tracking the car. Super happy with the change. The car is just better. No other way to explain in. No bobbing, more "solid" on the rough roads of NJ. IMHO you can't go wrong with a quality product.
I don't autocross, but I'm considering doing upgraded sway bars just to take a little more body roll out during a few of my favorite daily on-ramp curves. :-)
