996 Forum 1999-2005
Replacing lifters to address a misfire, some questions.
Old 06-05-2018, 08:40 AM
  #46
Charles Navarro
Charles Navarro's Avatar
Received 1,071 Likes on 557 Posts
Originally Posted by D6lc
Thanks guys, hopefully it will encourage others to give it a go, is not too difficult with basic tools. Glad to say that there were no leaks under the car this morning. finished off fitting the rear bumper and undertrays. Took the car for a 15 mile run, ran it to over 4k RPM to ensure the variocam triggers and happy taht there were no CELs. On getting home I ran the Durametric to check the Cam variation and its running at 1.72 & 2.02, well within specifications but honestly I was expecting it to be better.
The car runs great and I am very pleased with it. Going to take it easy for 500 miles then dump the oil and filter + drop the sump and make sure everything is cleaned up. After that I will get it hot and run it hard which used to trigger the misfire and CEL.
Total it cost me $2,694, $2,641 in parts, + $323 for the Injectors, LN low temp thermostat, oil, PS fluid and 5900 sealer. I'm sure it would have been a $6k job at a dealer. I could have done the intake lifters on the misfiring cylinders only for $500-600. But I think if your going to do a job do it properly.
All ready now for some summer useage
Don't be too hard on yourself. Your cam timing numbers are great. It's damn near impossible to have them be zero. Most new engines end up with a 1 to 2 degree variation :-) Good job!
Good taste in cars - love the Audi as well.
Old 06-24-2018, 03:58 PM
  #47
D6lc
D6lc's Avatar
Default Finishing off the thread
I have completed 400 miles since the rebuild, I dropped the sump to check it out and changed the oil and filter (the oil will be going in the Audi at its next change).
When you look at the sealant around the sump it is aged and looks very much like the sump has never been removed.
Pretty clean, no glitter. there were the following pieces in the bottom
The 2 larger pieces are clear brown plastic that is quite brittle. It doesn't look like chain guide material, not sure what that is. The 6 black pieces are hard plastic, looks very much like the chain guide material and would align with the slight wear I had on the guides. The bottom left is aluminium, it looks just like machining swarf and is the only metallic material in the sump.
With fresh oil in the car got it up to temp and drove it hard in the lower gears all the way to 7k rpm, car feels great. This hard driving used to without fail trigger the misfire CEL in the past. Got it home and plugged in the Durametric and all is clear, no CELs or pending.
So I am very please to say its fixed, hopefully this is helpful is you have a 3.6 with a persistent CEL that cant be addressed by the usual plugs and coils.
Old 06-24-2018, 04:14 PM
  #48
D6lc
D6lc's Avatar
Also meant to add, I decided to go back to the OE oil filter, it is just so much easier to dissect filters than the LN screw on filter adapter. So if anyone is interested I have a LN adapter for sale with only 400 miles on it. It clearly works great and is a beautifully machined part.
Old 06-24-2018, 07:45 PM
  #49
85eurocarrera
85eurocarrera's Avatar
what would you like $ for the adapter? I'm in minnetrista.
Joe
Old 06-24-2018, 10:40 PM
  #50
D6lc
D6lc's Avatar
Joe
PM’d you
Old 06-25-2018, 08:53 AM
  #51
dporto
dporto's Avatar
Received 1,154 Likes on 791 Posts
Nice work! Good luck with 'er... The brownish plastic looks like it was from the old cam chain tensioner pads (they start out whitish and turn brown with age/heat)... nothing to worry about as you've already changed them...
Old 06-25-2018, 11:53 AM
  #52
tomcat
tomcat's Avatar
I've gone back to the stock filter also. The filters from Porsche now come with the housing for about $35.
I have an adapter plate and tool to open the metal filters if someone is interested.
Old 06-26-2018, 07:44 AM
  #53
yelcab
yelcab's Avatar
My hat is off to you. I have done 30+ engine drops on my four post lift but never one in between the ramps. I am in the middle of one right now, and earlier 996 5 chain engine. I was looking for disassembly instruction but it looks like the engine is very much different.
Old 06-26-2018, 06:29 PM
  #54
PorscheAddict
PorscheAddict's Avatar
Great work, thanks for sharing.
Old 06-27-2018, 02:45 PM
  #55
dporto
dporto's Avatar
There are a bunch of posts/topics covering engine drop on jack-stands. Do a search, you'll find 'em. It's pretty straight forward - lots to remove, but nothing too difficult. Good luck
Old 06-28-2018, 03:08 PM
  #56
Chris(MA)
Chris(MA)'s Avatar
Who has the OEM plastic filter housing for $35? I might buy a new one as mine is 18 years old at this point. Thanks
Old 06-29-2018, 02:52 PM
  #57
yelcab
yelcab's Avatar
I have no problem with removing engine. Do that all day. I removed the engine last week on a 4 post lift with the engine hanging off the rear.
it's the disassembly of the 996-01 cam shafts that I am looking for. I did find some useful references and got what I needed
Old 06-30-2018, 01:01 PM
  #58
dporto
dporto's Avatar
I don't know if you saw this one, https://rennlist.com/forums/996-foru...urametric.html This was my experience with the dreaded 1341 code. Long thread but covers a lot of what you're looking for...
Old 08-01-2018, 05:47 PM
  #59
me61ic
me61ic's Avatar
So, have you had any other missfire since you put everything back together again?
Old 08-01-2018, 06:04 PM
  #60
D6lc
D6lc's Avatar
No, pleased to say all fixed with over 1,000 since the work. Getting it hot and driving it hard causes absolutely no issues. Where before it would flag a cell and misfire.
Quick Reply: Replacing lifters to address a misfire, some questions.
