loss of coolant but no puddle - Resolved: Leaky Rad
[I used to live in England, so I can sorta understand most of Aussie speak.]
Problem resolved
Mystery solved.
I have a leaky radiator.
I bought the car back in December from a Porsche dealership. they reconditioned the car before sales, including the major service. I guess that they never cleaned the rads as I collected a whole bucked to dirt.
the leaky rad is the big one on the driver side, there are a bunch of pin holes. I guess that the general thought is to replace it, other than fix it. Any recommendations on where to get one?
thanks for the moral support. I almost torched down the car
I suspect I have a similar issue due to a leak in that same area during winter storage. I don’t think it’s as bad as yours but curious to know the repair costs if you wouldn’t mind sharing .....
Received 1,085 Likes
Water cooling parts including radiators here https://www.pelicanparts.com/catalog...ing-System.htm
and here https://www.warehouse33auto.com/cata...Belts-Radiator
I replaced both of mine this year my RHS was leaking but replaced both whilst I had the front stripped down, and the coolant drained. I found the cheapest OEM parts were on Amazon, the 2 # were and
unfortunately I cant remember which was left and right. well priced from
for $415
Thanks for the recommendations.
I see that there are two part nr for the rads,
99610613151 and
99610613174.
they look the same to me but I suspect that the first is for all 996, and the second one is for turbo and 4S. are those interchangeable?
99610613151 and
99610613174.
It looks like the early ('98 - '01) radiators (99610613150/51) are quite a bit less expensive than the later ones (99610613172/74)...
Probably because they should be cheap. They r constucted with plastic tanks and aluminum fins. I can get jeep rads 3 times the size for under $100. I upgraded mine to the csf units. More money but better cooling, construction and direct bolt in.
the cheapest I found for my C4S part nr 99610613172/74 is $350USD. My local dealership here in Canada wants $1070CAD insane.
