Question on Heat Cycling of R Compound Tires
In the past I have always had my tires pre-heat cycled by the place I would buy them from. However, I just bought R888R tires for which that was not done with the intention of going out to the track for one session and then removing tires and letting them sit for 24 hours. It looks like I wont have time to do that before my first track day. Some of my friends say there is no need to do the pre heat cycle. What is the philosophy of you guys when it comes to that?
I wouldn’t stress it - assuming this is for a DE?
Try not to overwork the tires on your first session, let them come up to temp then give them a rest for an hour or so before the second session.
I would never pre heat cycle tires for just a DE. In a competition setting then all bets are off though
Brand new tires still have some of the mold release compound in them. If you don't heat cycle them at least once, that mold release makes the tires a bit greasy the first time out. Be careful that first session and let them cool afterwards.
Its typically done on parade laps by real race drivers. F1 preheats all tires but I’m not on an F1 budget? Are you? If so, I’d love if you could donate a lowly GT3 to my causes, even an 04 with high miles...
Thanks guys for the perspective....
I think based on what you guys say....this is what I will likely do.
1) Install wheels and tires at home and drive 35 miles to the track
2) Take car out at 80% for the first session
3) Skip the second session to let tires cool down
4) Do the rest of the six sessions.
Thanks again.
Thanks again.
Don't skip a session because of tires or any other reason. They are way too important to miss!
The way that I understand it, heat cycling also has to do with curing the rubber. When you first run the tires and heat them up some of the volatile compounds burn off to a certain depth and also the rubber gets stretched/compressed/kneaded. It is my understanding that when first running the tires, you don't want to "overcook" them as it burns out the volatiles to too deep a level for it to cure properly... and the kneading of the rubber is also important to the cure. You are supposed to go out for a few laps and build heat, then put the set aside for a week for the curing process to complete. In the end, buy curing the rubber you are supposed to get a longer usable life.
If it's a trackday event, then I'm with Slakker, too much fun to miss out. Just run'm.
Yeah I mean tires don't last forever.
I drove RE71rs 250 miles to an autocross. When I took the first runs the next morning they were garbage the first heat. But after a couple hours of cooling off, they were spot-on the second heat.
You got a reasonable plan,
Unless your in A/B run group you should be OK The drive there will rid release compound if you work the tires,
My Sport Cup2's usually take a couple warm up laps to come in, then last the whole session w/o becoming greasy like other brands.
I have a Powerpoint somewhere which Michelin sent/passed out for sizes and setups for most Porsche's, including pressures and temp ranges coming off track.
Let us know how it worked out. always interested to hear the "They don't squeal, right up to the point they let go"
Mike, now you have me all worried....I am in the intermediate group....I guess as someone earlier said....I am overthinking....I need to shut up and drive. I am picking my car up tomorrow... new engine and tranny with additional 100HP then the last time I drove it so a lot has changed.
I bought the same tires as you this year. First DE is in 2 weeks. My plan is to get them mounted and drive the back roads for 15 minutes and get them hot. Pull them off the car and let them sit for a week before the event. With the extra HP you have it should be quite the experience! Are you worried about breaking your new motor in?
