Door plugs
Door plugs
I am the proud new owner of a 2001 Porsche 911 Carrera Cabriolet. Should I remove the door plugs following a wash? I would replace after thorough draining.
Received 1,090 Likes
To access the bottom bolts of the window regulator. They are for adjusting the location of the bottom of the window regulator, i.e., in and out to set the window pressure against the window seal.
