Ceika Performance Coilovers - my review
all these brands, including feal, ksport, etc just repackage and rebrand the same stuff, no? I find it hard to believe that feal or ceika is doing anything other than sourcing some custom springs from the lowest cost supplier. Not to say that its a bad product, but what happens when these guys all go out of business in a few years or if you have an issue?
I went with bilstein/h&r setup and I'm regretting it, so I looked at Feal. While I want to think they are better than just getting the cheapest ones off ebay, I really don't think thats the case.
Going with Feal on my next race build. Custom valving/springs for dedicated track use (900#F/1000#R is my preference) and rebuilding their own shocks for $75/corner are perfect for my next build.
Ceika
Did you get/ need camber plates for the rear? What spring rate and valving did you get? I’ve have issues in the past with coil overs being rather bouncy on the street, do these have that issue?
For a street car, its a great setup. The ride on the progressive H&R springs is outstanding, and the handling is good. But the car has become more track oriented and the suspension is just too soft for a track car and you can't corner balance or adjust. This was intended to be an interim setup and things escalated more quickly than expected (should have known). So now seeking something a bit more track oriented
It's amazing how stiff springs can feel on the street and how soft the same springs can feel on the track.
My experience with offshore brand suspension parts is that they just don't do well in environments where Road salt is used . Seals go and corrosion gets so bad you end up replacing them long before you would if a more mainstream component was used .
it will be interesting to see how these units do 2-4 years out .
for my money , TUV approved German built parts like the h&r coilovers I used , with their bilstein hearts were worth it .
fyi factory gt3s came with h&r / bilstein joint venture coilovers .
it will be great to hear how these hold up two years from now . If they meet expectations they could be a real bargain !
My PSS9 had a blown shock, I wanted to try something new, was researching on pss10, h&r, ohlins, these are the brands that I had experience with on my other cars. I then decided not to spend so much money on coilovers this time, since I only drive my 996 for about 3k miles a year and it doesn't see rain/snow. I was then searching for BC coilovers which few of my friends are using on their weekend cars with good results. However BC doesn't make coilovers for 996 c2, so I went for ceika instead with custom spring rates. I chose 7k front 10k rear. The cost of the ceika are a lot lower than the german brands, which gave me the budget to upgrade other worn suspension parts. I replaced the dog bones, front/rear toe links with RSS units.
My ceika setup do give up some comfort when comparing to the pss9 unit, but they feel sportier to drive with my chosen spring rates. Overall I have no complains based on what that they are offering at this price point, you still get a quality product.
Here's how the car looks with the new setup.
The following 3 users liked this post by nivlek:
Stance looks great. What offset/tire combo are you running on rear?
And can I just say, headlights look badass on a lowered, clean setup 996.
TopPorscheFan (06-25-2020)
