Sooty Exhaust
#31
So you had the initial diagnostic and replaced both of the O2 sensors on Bank 1? The Pelican Part number you gave is:Oxygen Sensor, (After Catalyst)
Part #: 993-606-118-01-M14 There are two different O2 sensors required on each bank, pre-cat and post-cat:
99360611801 (up to 99) Post Cat
99660611800 (year 00 and up)
99360612801 Pre-Cat
http://www.autoatlanta.com/porsche-p...section=202-00
Did you replace both O2 sensors with the correct pre-cat and post-cat sensors?
99360612801 Pre-Cat
Are you saying the values are different?
I used Bosch universal ones for pre and post cat. You cut them to length.
#32
Hello,
if you look at the part numbers, there are two different oxygen sensors, one has a black and other a gray plug.
And even further, they differ between certain years.
#33
In other words. If you are looking into the engine compartment in the area behind the passenger tail light, you will see two connectors, one gray and one black. One is for the pre cat O2 sensor for the passenger side bank. The other connector is for the driver side bank post cat. And vice versa on the other side.
I installed Bosch universal sensors in my '99 which come with no plugs. I had to splice the factory plugs(one black/one gray) onto the bare ends.
I believe the different part numbers (Porsche) are due to the harness lengths being longer/shorter and black/grey so they will be plugged into the proper connector.
#34
As others have mentioned do your diagnosis tests.Don't just replace parts perform the test procedures per shop manual. It looks like you have some ego codes get shop manual and perform pinpoint tests.If you replaced the ego sensors but didn't clear codes and reset strategy you need to do that.
#35
Has any of you guys ever consider the 997 Vertex rebuilt engine for the 996?
https://www.vertexauto.com/porsche-9...-p-412036.aspx
#37
https://rennlist.com/forums/996-foru...-roller-2.html
Good thread on the topic^^
#38
#39
Hello Folks,
I've been struggling with this issue and I hope y'all can lead me towards a solution.
The passenger's side tips become very sooty after a few 100 miles. Originally I thought I may be suffering from bore scoring, but I had the blocked scooped and the shop concluded it was not oil on the tips and the rest checked out.
Long story short, bank 1 runs rich. The shop stated the car had two stored o2 sensor faults. I replaced them myself and it reduced it, however, the exhaust soot still builds up.
Things I've addressed:
-Cleaned the Mass air flow sensor
-replaced the plugs
-replaced the o2 sensors
There is no check engine light but I have a feeling I should replace the coils.
Thought?
-replaced the plugs
Thought?
#40
Hello folks,
Here is the update:
The engine was out and the following items were replaced:
-Chain guides and seniors
- cam potions sensors
- cam actuators
- lifters
- new MAS
- new plugs
- new coils - (which may be causing a static)
- New AOS
- and a few other things
The problem is still there.
I encourage my mechanic to change the injectors but he said they were fine. I am dropping the car off again.
I will be showing him this thread. He insists the sooty tip and running rich is fine but I think it might be hurting my engine to the point that I will need an engine rebuild due to his inability to fish out the problem.
Here is the update:
- cam actuators
- lifters
- new MAS
- new plugs
- New AOS
#41
Boost Meizer - I sold the CCWs and RH Wheels some time ago. Base on the issues I have been having with my 996, I will be parting with it and my original Porsche Speedline wheels might be on the market soon.
Thanks.
Thanks.
#42
Hello folks,
Here is the update:
- cam actuators
- lifters
- new MAS
- new plugs
- New AOS
$10,000 and 4 different attempts and the PROBLEM IS STILL HERE ! ! ! !
Here is the update:
- cam actuators
- lifters
- new MAS
- new plugs
- New AOS
I'm guessing the lifters got done because you had a ticking noise?
Since the passenger side tip is getting sooty and it's always bank 2 that scores first, you probably have a scored bore.
#43
What am I missing here, per the thread Bill linked above, Flat6 was saying this issue is most often attributed to tired fuel injectors. You pulled the motor, dropped $10k and didn’t change them? Not trying to sound smug, just confused.
#44
I did not read the section on injectors until today and I had the service completed a while ago. Iogged on today for to give future buyers my story.
Lastly, two shops prior, who solely worked on Porsches deemed it as “normal”. It has been a journey of unfortunate events with a clear lack of knowledge for these cars, on my part.
I’ll update the post after I speak to my mechanic.
Thank you all for chiming in.
#45
Hi!! Any news with this issue??
BR
