996 Forum
Sponsored by: LN Engineering
Inconsistent climate control
Old 03-17-2018, 05:42 PM
VFRMike
User
Default Inconsistent climate control
My climate control seems to have varying interpretations of what 72 degrees should feel like. Most of the time I just set my climate control to “Auto” at 72*, and usually that’s comfortable. Lately the car occasionally decides to pump out really cold air at 72* and I have to bump it up to 74 or 75 to keep the desired level of comfort. The ambient temperature display appears accurate, and I can get heat when needed. The symptom is more likely to occur after a re-start VS a cold-start, and most often at ambient temperatures below the mid-70s.
My mediocre ‘search’ skills did not turn up anything on the topic, has anyone else run into this?
VFRMike is online now
Old 03-17-2018, 06:42 PM
Porschetech3
User
Porschetech3's Avatar
Test for faults using Durametric (or PIWIS). Also do a search for "climate control hack", there are about 32 different values you can display on the climate control for various temps, door activation, sensors ect.
Porschetech3 is online now
Old 03-17-2018, 08:50 PM
fpb111
fpb111's Avatar
If the car has been sitting in the sun, especially the right side of the dash, it will pump cold air until it gets down to 72 at the temp sensor.
could also be failing temp sensor or temp sensor fan motor?
99-05 PORSCHE 911 996 RIGHT INTERIOR AMBIENT TEMPERATURE SENSOR OEM 99665324100
https://workshop-manuals.com/porsche...res/page_2858/
http://www.design911.com/Cabin-Tempe...96/prod136205/
https://www.ebay.com/i/253452196947?...D1470099914221
fpb111 is online now
Old 03-18-2018, 10:29 AM
DBJoe996
DBJoe996's Avatar
Make sure your outside air temperature sensor is plugged into the bracket in the front bumper and not hanging down or pushed through the bumper. The climate control system uses both outside and inside temperature sensors to operate.
DBJoe996 is offline
Quick Reply: Inconsistent climate control
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
