How cold is too cold?
Living in WI, I pretty much store my car in winter for a few reasons. For one, the streets are nasty with salt (literally coated with it so thick you can spin out on it), for another when they are not coated with salt they are coated with ice. Finally I usually spend time fixing/upgrading my car. I have read about cold weather bore scoring issues and was wondering how cold does it have to be to cause bore scoring issues? A few threads have hinted at single digits, but at what temperature are we safe from cold? Would that be like above 20F, above freezing?
Following.
Likely Charles from LN or FSI are the only people who can answer this. Although, with the recent arrival of reasonably priced factory short blocks maybe you just drive it.
Somewhere hidden in these forums Jake Raby speculates on some of the contributing factors to bore scoring in colder weather.
Letting the car sit at idle until it is warm. Allows the rich mixture to wash oil off the cylinder walls.
Running hard under load before the engine is fully warmed up. Causes the pistons to warmup and expand much quicker than the block does.
Porsche’s recommendation is to let the car warmup for a minute and then drive away gently (not sure if they use that exact word) until the car is thoroughly warmed up.
I live in MN which is at least as cold as WI if not colder and have driven my 996 for 2 winters without any issues. Porsche tests all their vehicles in extreme climates, so I'm not worried.
The issues I am referring to are not necessarily daily operation in cold climates, but rather the known bore scoring issues that are exasperated in cold climates due to tight clearances and pistons expanding at a greater rate than cylinders (at least that is how I understand the issue, someone please correct me if I am wrong...). I am hoping to know just how cold it has to be for this condition to exist, as I like to get out in April, after the salt is gone.
Sorry I'm going to have to disagree on that one... have an F150 I drove last winter and it's like any other 4x4 except the back end is so light you have to worry about spin outs and traction. The only issue I've ever had with my 996 was when the snow got too deep that it was a clearance issue.
Personally when I lived in new england I wouldn't drive my boxster in winter. The grit and salt will eat your car eventually, (see dporto's post) and even if you don't get to the point of rotting bodywork all the bolts/screws/aluminum underneath will corrode making every job on the car a roulette of "will this bolt head snap off?"
That is even before you think about if there will be increased risk of bore scoring or anything else.
I bought a cheap beater car and used that in winter
End hijack - Everyone who enjoys driving your 996 in winter, continue to do so and enjoy. This is not about how much fun in the snow the 996 is, I would like to get at the original question.
My original question - How cold does it need to be for cold weather bore scoring to be a concern? It is below 0, below freezing...?
Received 1,091 Likes
I don't think anyone can answer the question definitively...too many variables. Oil type/viscosity/age will play a big role, and so will how long it has been sitting, as in a daily driver vs one that sits for 2 weeks in low temperatures. Some people leave their cars outside in the freezing cold and never have a problem. Some are garaged but do develop a problem. It can go either way. I don't think someone can say yeah it is below 0, or below freezing...or anything below 50 degrees. Just my two cents....
