When to flush coolant? Coolant Expansion Tank Question
Just looking for a bit of advice here:
Ahsai has a great writeup for getting all the coolant out and refilling. Only requires removing a couple hoses and the drain plug. If your water pump is original I would do that too.
https://rennlist.com/forums/996-foru...pump-tips.html |
You do not have to completely drain the coolant system if your coolant is not that old. Remember, Porsche considers the coolant lifetime, but it is a good idea if you care about the car to do a coolant flush and refill if the coolant is over 3 years old. Since your job is the coolant expansion tank:
Car/engine stone cold Remove expansion tank cap Get a large roaster type aluminum pan and slide it under the engine as a drain pan Open the coolant drain plug on the bottom of the engine and start draining Once the level drops below the coolant tank, reinstall the coolant drain plug. You don't have to drain it all for this job. Replace coolant expansion tank...a PITA job because you will probably have to lower the engine Get one of those remote clamp removal tools for the spring clamps on the coolant tank hoses Once the new tank is in and fitted, fill the tank to somewhere between the min/max line with a fresh 50/50 mix of Porsche coolant and distilled water Leave the coolant cap off/or loose and start the engine. Watch the coolant level in the tank...it might drop a little bit Once the engine starts to get warm fully tighten the coolant expansion tank cap and manually open the burp valve on top of the coolant expansion tank Go for a short drive and get the engine up to temp Then go home and park. Leave the burp valve in the up position and let the engine cool down. Check coolant level again, add some if necessary. I leave the burp valve in the up position for at least 4-5 heating/cooling cycles to ensure the coolant level is stable and no air is in the system. Anytime I'm working on the coolant system, I always replace whatever amount I drain from the car with a fresh mix. Just seems like a good idea. |
Replace your AOS and your starter/alternator Y-cable while you are at it. Also replace all vacuum hoses for the SAI system as you will have access. Replace your water pump if it has not been done. Also replace the plastic coolant connector near the alternator with a metal one as they get brittle and snap off.
Originally Posted by DBJoe996
(Post 14850384)
Car/engine stone cold Remove expansion tank cap Get a large roaster type aluminum pan and slide it under the engine as a drain pan Open the coolant drain plug on the bottom of the engine and start draining Once the level drops below the coolant tank, reinstall the coolant drain plug. You don't have to drain it all for this job. Replace coolant expansion tank...a PITA job because you will probably have to lower the engine Get one of those remote clamp removal tools for the spring clamps on the coolant tank hoses Once the new tank is in and fitted, fill the tank to somewhere between the min/max line with a fresh 50/50 mix of Porsche coolant and distilled water Leave the coolant cap off/or loose and start the engine. Watch the coolant level in the tank...it might drop a little bit Once the engine starts to get warm fully tighten the coolant expansion tank cap and manually open the burp valve on top of the coolant expansion tank Go for a short drive and get the engine up to temp Then go home and park. Leave the burp valve in the up position and let the engine cool down. Check coolant level again, add some if necessary. I leave the burp valve in the up position for at least 4-5 heating/cooling cycles to ensure the coolant level is stable and no air is in the system. Anytime I'm working on the coolant system, I always replace whatever amount I drain from the car with a fresh mix. Just seems like a good idea. The water pump was replaced at the end of 2012, so the coolant is older than 3 years. Appreciate the input Joe!
Originally Posted by Nickshu
(Post 14850456)
I read the water pump should be replaced every 4 years as PM. So maybe now's a good time to tackle that anyway.
I very recently tackled the coolant tank and cap and added the following “while I was in there:” 1. Following asahi’s qrie up did a full purge and refill with new Porsche coolant and distilled water. 2. Water pump 3. Thermostat and housing 4. All rubber hoses in the area. 5. Pulled the front bumper off and cleaned rads. Not sure any of it was really needed but figured why not given these are all wear items and didn’t have records showing how recently they had been done. I now feel like the coolant system is positioned to handle the summer weather here in the Deep South in the coming months. |
Originally Posted by mrjonger
(Post 14851683)
Well, depending on your luck and how long it's been since you changed your pump...you may not have a choice soon. Good luck!
https://rennlist.com/forums/997-foru...xcellence.html This sentiment has been echoed by my reputable mechanic. |
(Post 14852040)
Originally Posted by jllphan
(Post 14851850)
I very recently tackled the coolant tank and cap and added the following “while I was in there:” 1. Following asahi’s qrie up did a full purge and refill with new Porsche coolant and distilled water. 2. Water pump 3. Thermostat and housing 4. All rubber hoses in the area. 5. Pulled the front bumper off and cleaned rads. Not sure any of it was really needed but figured why not given these are all wear items and didn’t have records showing how recently they had been done. I now feel like the coolant system is positioned to handle the summer weather here in the Deep South in the coming months. Water pumps has already been replaced. Thermostat might be a good idea, as it was replaced in 07. I'll take a look at the hoses in the area and figure out what I should replace. Bumper removed and radiators cleaned last month. :) |
Sounds good, if you're going to drain/refill, I'd def suggest at least changing out the main hose coming out of the bottom of the tank. It has a plastic connector that over time dries out and gets weak and will leak. IIRC, it's part#: 99610685006
For those debating the water pump, it's super easy to access and swap out -- not sure what the hesitation is to change periodically given the bearing does wear out and if it fails, it's blades can shear off and get lodged in the pipes or worse, in the engine. Sorry, but i have no problems spending a couple hundo and an afternoon swapping it out every 4-5 years vs way more trouble if neglected. Coming from BMW, the coolant systems in german cars designed for far more mild climates is just not something I leave unserviced. My $.02. |
That's fine its your car and you can wait for symptoms. But if the impeller blades come off, just make sure you check to see that you have all the pieces accounted for. Hasn't happened to me, but if pieces are lodged in parts of the cooling system, my understanding is that it can cause localized hot spots that may not show up on thermostat and cause some serious damage.
Or you could just change it every 4 years. Like JL said, I just don't think it's worth saving a few hundred bucks every 4 years. But I guess you can always flush the coolant to get all the pieces out if it does happen. Your car your call. Just a couple of notes of the coolant. I believe the cold coolant fill line is the min level, it should expand when engine gets up to temp. Slakker has indicated you can also add some water wetter. I put in a bottle, not sure if it did anything...I just had some laying around. Getting the clamps off, the clamp removal tool personally did nothing for me, channel locks were more useful in my experience. I don't know how people remove the tank without lowering the engine, if you can, you should probably be shade tree tech on the side. I think you will want lower the engine as much as you can - there are threads on how to do this. If you're as clumsy as I am, this might be helpful. https://cimg3.ibsrv.net/gimg/rennlis...408296774f.jpg |
