Tilt Mirror
Tilt Mirror
So when i search, all i can find are posts relating to how to program the auto tilt feature for the passenger mirror...
Does anyone know how to disable it completely?
Set your mirror adjustment control switch to the center or left. If it's to the right the swivel down mirror is activated when in reverse.
FriedEggs312 (03-16-2024)
From my memory, you put the shifter in neutral and hold the seat memory buttons (M-1 or M-2) to disable the auto tilt.
To enable, put the shifter in reverse and hold the same buttons.
Thanks for the helpful link. Maybe there’s some difference between model years. I have a ‘99. The mirror still tilts even programming according to the linked manual. Oh well. Small inconvenience.
Little know fact, the tilting mirror indicates the health of the IMSB. If mirror tilts, bearing is A-OK.
Ian Cooke (03-16-2024)
Out of curiosity, why are you so keen on disabling it? I find it to be very useful.
It should return to normal when you put it in a forward gear. That's a different issue.
This might be slightly obscene but I don't use it so there isn't additional wear on the motor from having to move as much. As im typing this im realising how ridiculous it sounds...
Re-enabling it next drive haha
Actually I only realised it had been enabled after my dad drove my car and pressed M1 and reversed and the mirror tilted, I actually thought I hadn't configured it correctly. Out of everything on a 996 IMO configuring this setting isn't easy.
I cant get mine to program NOT to do it, and its a 50/50 shot if the thing actually returns back when taken out of reverse. If i get to irritated I am going to snip a few wires to put a end to the madness.
