Installing MOMO wheel and clockspring?
Going to install my new MOMO steering wheel along with a model specific wheel hub. After removing the wheel, do I also need to remove the clockspring to accomodate my hub, or does the hub attach on top of it?
Car is a 1998 996 mk1 C4.
Thank you!
Thank you!
I have a brand new Momo steering wheel and hub that I've been contemplating installing while I have a lot of COVID-19 induced spare time.
Thanks for reviving this thread!
Let us know what you find out. Is there a factory part to satisfy the airbag light like in my 964?
Clock spring will have to be removed to install aftermarket steering wheels. You will have to splice in a resistor to the airbag wires to defeat the light. You will also need an L-bracket and connector pin to retain horn function as well. With the clockspring removed, you will still have turn-signal cancellation as long as you adjust the steering stalk to sit flush with the aftermarket hub.
https://rennlist.com/forums/993-foru...ng-photos.html
