O2 sensor adapter/extenders for stock 996 cats
I've gone through the trouble gutting my cats on my 2003 C4s because the cats started rattling.
I'm looking for someone that has installed the extenders/adaplters on hollow cats. There isn't much room, I was wondering which adapters work the best in the limited space when retaining the cats.
thanks
Glenn
thanks
Glenn
Electronic simulators
After doing some research I found that there are electronic simulators that either connect to the O2 sensor and smooth out the signal, or completely replace the O2 sensor. Does anybody have any experience with these? Thanks Glenn
Received 1,091 Likes
I think you need to be mindful of the pre vs post cat O2 sensors and what they are telling the DME. I found this setup from Fabspeed and you might want to contact them about what is the best setup - https://www.fabspeed.com/universal-9...ic-converters/
