Non-IMS/RMS Failures - High Mileage 996s
First time poster, long time lurker. Have done some extensive searching and gotten some answers, but looking for a few honest opinions.
Long-story short: aside from IMS/RMS failures, timing chain tensioner ramps, and perhaps bore-scoring, what likely failure points are there on these cars at high mileage that would lead to a full rebuild?
Long story:
I had a PPI done a very nice example of a 996.2 this week and received a squeaky clean bill of health from a reputable shop. Car has about 110k miles on it, but has a lengthy service history and has been maintained by reputable shops or the dealer for all of its life. Clutch and IMS were replaced about 6 months ago by an LN Engineering certified installer, so little to no qualms there.
After delivering the clean bill of health, however, the individual who performed the PPI basically gave me a rather plain warning about high-mileage 996s. Mentioned timing-chain tensioner issues, of which I'm aware, but pretty plainly told me that he'd be shocked to see me get more than 30k miles more out of the car before it needs a rebuild, and then followed it up by telling me it was one of the cleanest 996s he's seen and had no reason to believe that the engine had a single issue.
I was ready to pull the trigger on this thing if it got a clean bill of health on the PPI, and I'd like to think I've done my homework and research watching these cars for 12+ months trying to pick my spot to jump in, but I'd be lying if I said I wasn't rattled by the conversation. I can handle the expense if the worst happens, but I struggle with the concept of having 100% of the purchase price into an engine rebuild when I've intentionally sought out a particularly clean example. I get the feeling that the answer to that may be "Then 996 ownership probably isn't for you", and if that's the answer then it's the answer, but I'm trying to decipher if I've been put into a tizzy by an air-cooled snob with a hyperbolic opinion of 996s, or if I've actually gotten some sage advice.
Any help would be greatly appreciated.
Long story:
My 2 cents. I bought a 2002 C2 six years ago with 100,300 miles. Excellent service history, driven regularly, original IMS. I decided to finally do LN IMS at 144,000, but car was fine.
Just turned 170,000 last week. Runs like a top and I drive it everyday. I use DT 40 oil, LN filter adaptor and magnetic plug. Oil analysis all look good so far.
I think you should pull the trigger, based on your description. I love this car.
Read these opinions...https://rennlist.com/forums/996-foru...weet-spot.html
I wonder if the mechanic wanted it?
1) Obviosly, anything can happen at any time, but you’ve done everything you can to mitigate the possibility of that.
2) 130k is not a lot of miles for a well maintained engine. ”High mileage” is relative to the age of the car - if you average it out it’s probably less than 7-8k a year... that’s not high mileage in my book (certainly not in my book)
3) The two posts above make some good valid points. As long as you stick with the maintenance schedule, I think you’ll be driving it for quite a while.
...I was ready to pull the trigger on this thing if it got a clean bill of health on the PPI, and I'd like to think I've done my homework and research watching these cars for 12+ months trying to pick my spot to jump in, but I'd be lying if I said I wasn't rattled by the conversation. I can handle the expense if the worst happens, but I struggle with the concept of having 100% of the purchase price into an engine rebuild when I've intentionally sought out a particularly clean example. I get the feeling that the answer to that may be "Then 996 ownership probably isn't for you", and if that's the answer then it's the answer, but I'm trying to decipher if I've been put into a tizzy by an air-cooled snob with a hyperbolic opinion of 996s, or if I've actually gotten some sage advice.
This mechanic could also give you the same advice about any car this old with similar mileage. Even an air cooled car - just price out a top end rebuild on a 993 - not much different than a mild rebuild for a M96. There are thousands of these engines happily racking up miles well in excess of 100K. This doesn't seem like sage advice to me. Your mechanic can and should check for wear items in the PPI - you should also know the oil change intervals of any used M96 power plant - if not heavily discount your purchase price for the added risk.
Remember all engines will require rebuilds at some point. It's not a matter of if, just when. With no indication of a rebuild needed now, you're not taking much of a risk. If the camshaft deviation numbers were off, if there were range 2 over-revs, if the oil hadn't been changed in 2 years and was slowly eating away at the plastic internals, if you found metal in the sump during the PPI, if there was a huge amount of deferred maintenance needed, then you'd budget for a rebuild soon and adjust your purchase price way down. Don't over think it.
I am interested in some opinions on high mileage cars other than just the motor. I am looking at a 180k mile '99 with a rebuild at 140k by a very well known local shop. Other than the motor, what are some of the (equally) expensive items that go wrong?
To the OP: You'll get answers all over the place on this one. Very knowledgeable guys at LN will tell you anything with more than 20-30k miles will have cylinders out of round. At the same time, there is no shortage of guys running cars with well over 100k miles and no apparent issues. Mine has 115K and the PO and I have been doing UOAs with Blackstone since about 100K and so far no concerns. Its a bit of a crap shoot. The M96 seems to be a bit more failure prone than than a Toyota Camry or Honda Accord. That said, a well maintained M96 engine with the known failure points addressed does seem to be generally reliable.
As to the other wear items, they are pretty much anything you'd find in other higher mileage car - shocks, plastic expansion tank, water pumps with plastic impellers, alternators that seem to crap out right at 100k miles, a few electronic valves that comprise the evap system, and belts and hoses seem to be the common issues I've come up against. None of these are deal killers and they are all pretty cheap, just things to stay on top of as they happen.
Bah, 130k on my '99 which is still going strong... "Jump in somewhere" is correct, buy something and drive it. I love mine, and even if I have to rebuild the engine, I'm in for less than a used Camry.
