996 Forum 1999-2005
Wait for it to grenade and then....?????
Old 02-24-2018, 09:16 AM
JimmyChooToo
JimmyChooToo's Avatar
Originally Posted by lowpue
I am torn on this dilemma too....But here is my story....I put in LN IMS at 47K miles....last summer the car grenaded at 54K miles because of oil starvation on the crank/piston bearing. Putting in a 997S engine now (with factory IMS) so in the end I could have saved the IMS cost. At 140K miles my view is drive until it dies...even with a new MS something else can go. Though it will be expensive, there are so many options for another engine.
I agree. At 140k, this is the sound strategy. Put the money towards extra oil changes and oil analysis. And get the magnetic drain plug. I bought my ‘01 at 68k and I sleep great at night doing nothing but oil changes and flooring the accelerator A LOT.
As one ‘Carrera Wing’ owner to another, congrats on the new ride!
JimmyChooToo is offline
Old 02-24-2018, 10:39 AM
Mikelly
Mikelly's Avatar
Originally Posted by Coopduc
Mikelly- when you say 3.8 do you mean a 3.4 engine modified to 3.8, or do mean an engine swap 3.8 engine from a 997?
Honestly it depends on the cases I get when I start shopping. The car I drove was a 3.4 to 3.8 conversion that UFO put together. It had 38K miles on it since the build and ran flawlessly. Car was a bit beat up otherwise, but I'd have bought it for the motor/transaxle/body. Ran like a Turbo with K16s. Was WAY FASTER than my 996GT3 was from a stop.
Mikelly is offline
Old 02-24-2018, 10:57 AM
Mike Murphy
Mike Murphy's Avatar
Received 1,578 Likes on 985 Posts
Cars are like people. The exact same DNS and components, yet some are amazing and some are turds. Your car is not a turd. It made it to 140k. It has a good track record. You could roll the dice and just drive it. Do the oil filter inspections and keep track of any changes. Save your money over time and buy that new engine over time.
Mike Murphy is offline
Old 02-24-2018, 11:29 AM
az968gpw
az968gpw's Avatar
The PO had the IMS go at abt 30k, The car then sat in his garage for over a year before F6I was able to get to his, wait list is something like 13 months. Then did the 3.8 and IMS Solution. Hell of an engine it is! And it should be more reliable than a stock engine.
But, do you want to wait over a year to have your car back on the road after it detonates?
If the car is as nice as you describe, and you are happy with the HP, and plan to keep the car for a long time, then plan to take care of the IMS. The IMSB will eventually fail, it will. But it may be a long time coming and something else might get the engine first. Keep on top of the oil changes, etc and you may catch it before it's too late.
az968gpw is offline
Old 02-24-2018, 03:38 PM
Splitting Atoms
Splitting Atoms's Avatar
Many of the responses have to do with probabilities and statistics. I think there is a psychological aspect to installing the IMS Solution. If you are reluctant to drive the car, or have this thought in the back of your mind that it could grenade at any moment, I think it's worth a few thousand dollars for the peace of mind. Sure there are other things that can take out the engine, but other than bore scoring and a failed rod bolt, most can be detected and corrected.
Splitting Atoms is offline
Old 02-24-2018, 04:14 PM
az968gpw
az968gpw's Avatar
My engine has the IMS Solution, as well as the 3.8 build, and that's why I bought it. I will never have to worry about the IMS issue ever. Splitting Atoms has a good point about piece of mind. Thus , if you like the car enough to keep it for a long time, that certainly is a good solution. No fuss, no.muss.
az968gpw is offline
Old 02-24-2018, 04:40 PM
HenryPcar
HenryPcar's Avatar
Only you can answer that question. Normally when I get a used car, it eventually ended up better than the original condition after I'm done with it. That's just me, because I couldn't stand imperfections on my cars. Then there are those that just knows how to put gas in a car and drive it till it totally falls apart.
HenryPcar is offline
Old 02-24-2018, 07:00 PM
lowpue
lowpue's Avatar
Originally Posted by Mikelly
My plan as of now is to drive my 99 until it grenades. I'm slowly starting to shop for engine cases and will buy the parts for the 3.8 engine build. I drove a 2000 model with a 3.8L in it and was stunned by the torque and power. This is the route I plan to go SLOWLY over the next two years.
I took apart my old engine that grenade....the case had 54K miles and no porosity....My shop says its good for anyone who wants to resleeve since two of the cylinders are toast. I have put in a 997S engine so I won't ever need them.
lowpue is offline
Old 02-24-2018, 08:34 PM
AzDropTop
AzDropTop's Avatar
My 02 had 108K on it when I bought it. At 113K I had an LN bearing put in. The one that came out looked fine other than the fact that there was oil in it. At 140K i suppose there are a bunch of other things that could go wrong so whey not save the 4K at this point and sew what happens?
AzDropTop is offline
Old 02-25-2018, 06:09 AM
Audidude
Audidude's Avatar
Best answer.
Audidude is offline
Old 03-13-2018, 09:34 AM
Evil Bunny
Evil Bunny's Avatar
Could you share the details on this? Do you have a build thread?
Evil Bunny is offline
Old 03-13-2018, 03:43 PM
5CHN3LL
5CHN3LL's Avatar
Data point: Bought my '99 with ~45K miles 5 years ago, put the money into a dual-row retrofit (Solution did not exist at this time) and a few other odds and ends. Car is currently at about 85K miles; no significant failures beyond a fuel pump, a couple of MAFs, and a few other odds and ends. I think it's probably accurate that, excluding tires, I put more into the car doing the preventive work when I first acquired it than I have in the intervening years. Spin-on adapter and TOTAL Quartz Energy 9000 5W40 Full Synthetic (the oil recommended by my indy shop, which is very M96 literate).
If I had it to do over again (today), I'd do the same thing, except the Solution rather than the dual-row hybrid retrofit bearing.
5CHN3LL is offline
Old 03-13-2018, 05:20 PM
Audidude
Audidude's Avatar
Pretty much sums up my approach too, except mine's an '03, so single row bearing, which is slightly more of a worry....if I ever get the mileage up enough I will go with The Solution.
Audidude is offline
Old 03-13-2018, 11:14 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
My 14 cents.
Drive it like ya stole it. when the engine grenades, buy a cheap-azz 3.2L Boxster engine off ebay. Put in the new bearing kit, RMS and any other minimal stuff you want to do. Swap it in to the 996.
Lather, rinse, repeat. You won't know the diff of the missing 40-whatever HP.
YMMV, don't try this at home, may cause **** leakage.
docmirror is offline
Old 03-14-2018, 09:01 AM
501Max
501Max's Avatar
If you wait until it grenades- you can cost yourself $$$ with other parts that become damaged during grenade event. Those $$$ could have been put towards a solution. My less than .02 worth says give FSI a call about options/facts- Jake and his team are top shelf. Of course- I am a bit biased with the FSI bundle pushing mine around.
501Max is offline
Quick Reply: Wait for it to grenade and then....?????
