Has anyone here replaced E-Brake cables?
My right rear E/Parking brake cable has broken off at the short tube that goes into the back of the mounting plate. It rusted right at the steel end where the cable enters the aluminum tube. The drivers side cable still works, but is rusted as well and it's probably only a matter of time 'til it breaks as well. I've already ordered the cables and tubes and I'm awaiting their arrival (from AutoAtlanta). I can't seem to find any info besides adjustment of the the parking brake...
^^Yeah^^ - difficult not to once everything is apart... I guess once I get the new cables it should be obvious how everything comes apart and goes back together. ** I haven't been able to find any info on this job... when I'm finished, I'll write it up.
There is a write up in the rear e-brake pad in the Pelican 101 Projects book. I don’t recall it covering the cable, but other than the corrosion, it should be pretty straightforward, unbolt the handle end and slide it back through the tube. Assembly is the reverse of removal
I've got 101 projects...nuffin! These things are always obvious in retrospect - I was just hoping to have some reference before hand so I don't go and break something...
At both attachment points it is pretty straightforward. Where the cable meets the body, you'll need to use some force to get them out. They are held in just by pressure. I find a vice grip works. Lock them on, and twist back and forth until it breaks loose.
^^That's perfect^^ Thanks Kris - sort of what I thought (though I was worried they might be threaded - figured I'd just wait 'til I got the new ones). I put some channel locks on them last night, but they didn't budge...Vise-grips next!
I got the vice grips on them last night. Tough, but they came off. What I couldn’t get out was the old rusted cable end that had broken off at the rear right wheel. I had to cut it off with the Dremel tool...
The first photo is the cable end that rotted and broke. The second is the tube that the cable passes through at the back of the wheel. The third photo is the pin that holds the end of the cable to the peice that expands the e-brake shoes when you pull the lever. The pin is an interference fit and comes out with a punch. I used a pair of pliers to press it back in to the new cable end.
Just to close out this thread, I finished the parking brake cables on Friday night. Once I figured out that the cables just sit in the "tubes" (Thanks again Kris Murphy), it was pretty straight forward. One of the trickiest things was getting the short tubes inserted in the back of the wheel carrier. Due to it's location behind the front control arm, it's difficult to get a hammer or mallet on it. What I wound up doing was using a long extension with a socket that went over the tube (to sort of hold it in line) and tapped it in - you don't want to maul the end of the tube because the cable end is a snug fit and it's got an O-ring that you don't want to tear up.
doth tube come wit the cable or a separate part
Wow ok little nervous to do this one but that cable will pull out and the new one goes in easy or did you run a pull string through when removing the old one? I know this is a lot of questions I'm just trying to wrap my head around this tha ks guys.
