996 Forum 1999-2005
new rookie owner, dash light question
Old 02-13-2018, 02:48 PM
vwtdi
7th Gear
vwtdi's Avatar
Default new rookie owner, dash light question
2003 base coupe. It’s the small led light above the dash light adjustment **** in the middle of the picture. I drove it for the first time to the gas station today and it was a solid green normally, but would turn red intermittently while trying to tell me something I wasn’t understanding. I came right home and can’t find it in my owners manual. I know....dumb question I’m sure, but I will know the car inside out eventually . Thanks.
Old 02-13-2018, 02:57 PM
GM996
GM996's Avatar
I don't believe that's a factory light. Are there any aftermarket systems installed that you know of (possibly an alarm)?
Old 02-13-2018, 03:00 PM
DBJoe996
DBJoe996's Avatar
Received 1,085 Likes on 697 Posts
Maybe an aftermarket radar detector...stealth mode?
Old 02-13-2018, 03:04 PM
jllphan
jllphan's Avatar
^This. I have an afterrnarket radar/laser jammer that a PO installed on my car and looks similar, albeit the install on your's in cleaner. Blow by a cop at 100 and see what happens!
Old 02-13-2018, 03:17 PM
Dr_Strangelove
Dr_Strangelove's Avatar
Hey vwtdi, look in the openings for your radiators up front. Do you see any sensors in there that look like the attached? This is a photo of a laser jammer sensor, but you might also have a radar detector sensor up there as well which would look a little different.
Old 02-13-2018, 03:54 PM
vwtdi
7th Gear
vwtdi's Avatar
You guys are good. I have something similar to Dr Strangelove's picture on both sides. When it goes off (which seems like a lot), it turns red, beeps, and also has voice once in a while. I may have to find a way to turn it off. Here it is.
Old 02-13-2018, 03:59 PM
vwtdi
7th Gear
vwtdi's Avatar
Forgot....thanks everyone, appreciate the help and a little relieved.
Quick Reply: new rookie owner, dash light question
