Metal in Oil Filter and Blackstone high Copper
Looking at the other threads, seems like the size and number of particles in the filter isn't abnormal and the Oil Report seems to say the same. Can any of the experts here really say there is a problem?
2003 911 cabriolet, about 57,000 miles on the motor. Oil and filter was changed about 10,000 miles ago. This is the first filter I've inspected, so seems I should be doing it more often, right? Thanks, --Don https://cimg9.ibsrv.net/gimg/rennlis...9be67fd41.jpeg https://cimg1.ibsrv.net/gimg/rennlis...f4abf0086.jpeg https://cimg3.ibsrv.net/gimg/rennlis...3bd5bd711.jpeg |
For one thing, stop running your oil for 10,000 miles. Start doing 5,000 mile changes.
Isn’t the blackstone analysis recommending increasing to 12,000 mi.? |
Originally Posted by LexVan
(Post 14794676)
I hate those cSt and SUS viscosity values. Looks like the classic Mobil 0W40 shearing, since they are on the very low end of the range. You live in CA. Run a high quality, Porsche approved A40 oil in the 5W40 flavor, or run the Mobil 5W50. Also get a magnet billet drain plug from L&N Egnineering.
I think you are losing a bearing. The metal looks like a bearing shell fragment and these have copper. If you haven’t already, you will lose your crank, and maybe a rod and damage your head if you keep driving. The distance between the piston and head at TDC is smaller than the thickness of one bearing shell. Lose a bearing shell and the piston will probably hit the head. You are looking at a total tear down if you want to get all debris out. Continuing to drive will damage some more expensive parts. The short block deal in the other thread would be a good deal for you, maybe. This would be a good test for what the definition is for an acceptable core. |
Originally Posted by donking
(Post 14794655)
2003 911 cabriolet, about 57,000 miles on the motor. Oil and filter was changed about 10,000 miles ago. This is the first filter I've inspected, so seems I should be doing it more often, right? Thanks, --Don https://cimg0.ibsrv.net/gimg/rennlis...14192d222.jpeg The wear levels of all the metals are concerning as well. |
Ticking time bomb!
Originally Posted by 808Bill
(Post 14798018)
Ticking time bomb!
(Post 14794676)
Originally Posted by jhbrennan
(Post 14794770)
Agree - 5K miles or 6 months whichever comes first. Ignore the 12K recommendation. BTW, did the car really go 4 years between oil changes?
(Post 14798018)
Ticking time bomb!
Originally Posted by Woodman71
(Post 14798040)
Doh
TIA, |
Originally Posted by Charles Navarro
(Post 14797432)
That's piston skirt coating. It peels off and has a ribbed appearance from the machining marks on the piston skirt (and also why it's not flat and is slightly curved). You are going to have scored cylinders, if not already scored. I would also be concerned you have a bad injector that is leaking fuel. I'd check your fuel trim values for FRA and RKAT. Both should be 1.0 in a perfect world.
The wear levels of all the metals are concerning as well. Also, how does leaking fuel cause this to get into the oil? The analysis shows little fuel in the oil. Thanks again, |
(Post 14794809)
Thanks, |
Drop the oil pan and see what else you find. If Charles says it is an issue, then it is an issue.
I wouldn't even start it.
Originally Posted by Slakker
(Post 14800169)
