Porsche remanufactured short blocks
#151
Byprodriver: I think you'd run into issues in the chain drive if using 3.4 heads. I think you'd run into computer issues if using the 3.6 complete as it has variocam-plus instead of variocam. If you find a way, please share!
Also, the dealer does not care what condition the core is in. I bought a 3.4 longblock with a rod failure for 1K, then stripped off the heads; using the busted shortblock as my core.
#153
Charles: you would be the best resource for this question: Can you use a 3.6 shortblock in conjunction with 3.4 heads? (assuming the chain drive gear is the same; or a 3.4 chain gear could be pressed onto the crank.
#154
Where there is a will, there is a way. The castings are very similar, but there are some differences in the chain wells that have to be overcome to make such a marriage.
#155
[QUOTE=gtred;15235245]Byprodriver: I think you'd run into issues in the chain drive if using 3.4 heads. I think you'd run into computer issues if using the 3.6 complete as it has variocam-plus instead of variocam. If you find a way, please share!
Which is why I recommended he not do that & buy my rebuilt engine instead:
2001 3.6 litre rebuilt engine
#156
[QUOTE=Byprodriver;15236663]
I’m surprised you still have it!
#157
This is a great thread. Worth the revive. Especially since I just bought a short block yesterday!
TexSquirrel (01-13-2022)
#158
From where who and how much please
#159
Eurocarguy911 (01-14-2022)
#160
looks like they are on sale. $4 off...
#161
I’m not mechanical but have questions I own a 99 911 with the 3.4 if/when my motor goes can I use the 3.4 heads and ancillary parts to mate them to a new 3.6 block
what needs to be done
thanks
thanks
#162
No the 3.4 and 3.6l r very different motors inside.
#163
Ok great I will continue to research 3.4 possibilities without going to JR
#165
3.4 short block. Went all the way to check out and they never asked for a core charge. Free shipping. I would think you might get a call when you do checkout about your core?
https://www.ecstuning.com/b-genuine-...l/996100951tx/
