My roller
#76
Former Vendor
#77
Same. I use 8mil and they are tough as skin. I've had some 9mil I liked but they were black. The colors let me see if my gloves are dirty when working on the interior.
#78
I always seem to start out each job with 5mil nitrile gloves, but as soon as I need to “feel” the threads of a bolt, I take them off and they stay off the rest of the job.
I was just diagnosed with bladder cancer. (and I’m recovering from surgery)
One cause is workplace chemical exposure.
I’m guessing it could be from my professional wrenching years ago, or my current DIY wrenching.
I’ve promised my wife I’ll try to use nitrile gloves more.
I only started using nitrile gloves about a year or so ago.
#79
Friday the 13th strikes again. I decided to be proactive and send my fuel injectors out the be cleaned and tested prior to installation. I chose Whitchhunter Preformance, based on customer feedback. I packaged them up exactly per Whitchhunter’s instructions, clean, wrapped in paper towels, and in a zip lock bag. Put everything in a USPS flat rate box along with extra bubble wrap and the required paperwork. This afternoon I got a call from Whitchhunter, the box was delivered but no injectors were inside! Interestingly, the bubble wrap and paperwork was still there. They promised pictures of the box as received, but I don’t see any way to recover the injectors. Of course, I didn’t purchase the extra insurance. Lesson learned. I almost fell over when I checked the price of new parts! Even rebuilt ones are high without cores to return.
#80
Originally Posted by Coopduc;1494115[left
Friday the 13th strikes again. I decided to be proactive and send my fuel injectors out the be cleaned and tested prior to installation. I chose Whitchhunter Preformance, based on customer feedback. I packaged them up exactly per Whitchhunter’s instructions, clean, wrapped in paper towels, and in a zip lock bag. Put everything in a USPS flat rate box along with extra bubble wrap and the required paperwork. This afternoon I got a call from Whitchhunter, the box was delivered but no injectors were inside! Interestingly, the bubble wrap and paperwork was still there. They promised pictures of the box as received, but I don’t see any way to recover the injectors. Of course, I didn’t purchase the extra insurance. Lesson learned. I almost fell over when I checked the price of new parts! Even rebuilt ones are high without cores to return.[/left]
#81
I "think" I have 3 extra sets -1 in my basement. I will check this weekend and see if I can put my hands on them, they are in different boxes in no particular order. I only need one extra set for an extra engine rebuild on a stand ,that I am half way finished, but in no particular hurry to finish.
#84
Lack of updates indicates lack of progress. ☹️
I filed a claim with the USPS, they kindly sent me a check for $50...lesson learned. I was able to find replacements on eBay.
Regarding the engine build, for the last 4 weeks I’ve been waiting for misc small items to arrive. The most significant are 2 heat shields as shown in red in the pic. I noted they were not present when I disassembled the heads, but forgot to order earlier. Of course they were back ordered from Germany. Good news is they will be delivered next week. I don’t know if the original engine failure digested these parts or if some hack shop omitted them during a service. My guess is the latter, based on P.O. comments about the shop that did the original head swap.
#87
Ooops, I got busy and forgot to look for those injectors in my basement, Sorry. glad you found some !!
#88
Finally my parts arrived!
I thought these were heat shields, but Bentley calls them oil baffles.
Whatever, they were installed about 2 minutes after they arrived.
Next was the lifter housing and lifters.
Old chain pads, in foreground, were in bad shape, so I installed new ones. Not sure why the color difference, new ones are genuine Porsche parts.
Pre-assembled cams, timing chain, and solenoids.
Bank 1 Cams installed.
Timing chain sprocket torqued.
Bank1 buttoned up! I’ll do bank 2 tomorrow.
#89
Sure glad I found this post. Pm'd you about it and looking forward to the outcome!
Thought I had the only "My Roller" thread...
#90
I’ve made great progress since my last post. Here you can see I’m in the final stage of engine assembly before it goes back in the car. All has gone smoothly until I try to install the engine support plate. There is an interference with an oil pump bolt that did not exist before. I’m trying to figure out if Porsche made a design change that affects this area and I can grind a relief cut into the plate to create clearance. Looks like it needs about 10-13mm half moon cut to clear. Here are some pics.
